Yo Babs,
Ok, E4OD.
Does it shift hard in both forward and reverse?</span></span
Or just forward? etc.
Check Engine Light (CEL) comes on when the electronic engine control system is not working properly. The check engine warning indicator comes on briefly when the ignition switch lock cylinder is turned to ON, and should turn off when the engine starts. If the check engine warning indicator does not come on when the ignition switch lock cylinder is turned to ON or if it comes on while the vehicle is moving, the system is malfunctioning.
If the CEL does not light up at all when starting it; then suspect that bulb is burnt-out or loose, socket was damaged by PO or shop, etc. or someone removed it.
Is CEL ON when starting or while driving?
Same for:
E4OD Transmission Control Indicator Light (TCIL) , it is a LED and overdrive on/off switch at end of the Transmission shifter stalk; flashing OD light is an indication of a transmission related trouble code in the Powertrain Control Module (PCM).
Is it flashing while driving?
Do a SELF TEST for diagnostic trouble codes (DTC)s by my pal BroncoJoe @
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some possible suspects for harsh forward only:
vehicle wiring harnesses, powertrain control module, throttle position sensor, vehicle speed sensor, Electronic pressure control, etc.
fyi, see
http://broncozone.com/topic/22440-drivetrain-identification/
