DSOUTHERNER
- Joined
- Mar 25, 2017
- Messages
- 6
- Reaction score
- 0
I just installed a 6" Rough Country suspension lift kit with ad-a-leafs and blocks to my 91 351W Auto Trans 4wd and the driveshaft angle on the rear is now way off. It's a stock Double cardan shaft, everything I've read says I need to get the Pinion angle to match the driveshaft angle to eliminate the VERY BAD vibrations it's causing.
I measured my angles with two magnetic angle gauges, and from front to rear they are:
Transfer case 4° Down. U Joint #1 to #2 "H" ****** 12° Down. Main Driveshaft 25° Down. Pinion at ****** 10° Down. Shaft length Ctr to Ctr 28 3/8". Difference between Driveshaft and Pinion angle 15°
If I understand all of the guides I have read on aligning the Pinion and shaft correctly, that means I need additional axle shims at 13-15° (-2° was recommended to account for flex at "cruising speed")
The highest pre-made shims I can find anywhere top out at 8° max. Which is making me question what I'm missing since I need nearly double that.
The best cause for the angle being so extreme seems to be the Automatic transmission being longer than a standard, thus using a shorter shaft at a more extreme angle.
I know people throw 6" lifts on full size Broncos all the time, so I'm sure I'm not the first one to encounter this; thanks for any help.
