Wiring and Vacuum Diagrams
cmedivr
Does anyone have a good source for accurate diagrams for Full size broncos. Have looked at Hanes and some other they have mostly generic diagrams. I would like to find an OEM shop manual with detailed information. Thanks
C
cmedivr
HELP; My grandson bought a 1984 full size bronco that has under gone the knife of a hack artist. As far as I can tell the body is a 1987,motor a 1984 351W the trans a C6 (year unknown as of now). The wiring and vacuum systems have multiple connectors not connected, currently looking for diagrams to help in correcting the unused connector issues. The motor has carb issues (edelbrock 4 bl) looking for suggestion on replacement or rebuild info on it. Also any info on a decent exhaust system would be appreciated.
Yo cmedivr,
Hack jobs seem to crop up too frequently.
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @ http://www.revbase.com/BBBMotor/Wd
For an overview of typical changes made in an EFI Swap to a Carbureted system, see http://broncozone.com/topic/25453-1990-efi-to-carb-conversion/
Exhaust, our sponsor has a dual system @ http://shop.broncograveyard.com/80-87-Bronco-351w-Dual-Exhaust-Kit/productinfo/30096/
Or,
1984 FORD BRONCO 5.8L 351cid V8 :
Exhaust & Emission : Muffler Price $71.79
WALKER 22382 Click for more information about this part
Heavy Duty HEAVY DUTY MUFFLER; HEAVY DUTY Offset Inlet-Offset Outlet / Inlet Dia. 2-1/4" Outlet Dia. 2-1/4" Shell Dia. 6" Shell Length 24" OAL 30"
$71.79
http://www.rockauto.com/m/mobilecatalog.php?make=FORD
Exhaust & Emission : Tail Pipe Price$12.59
WALKER 45860 Click for more information about this part
Part Image
See other parts listed such as;
Muffler Hanger / Insulator
Muffler Strap
Heat Shield
Exhaust Manifold Gasket
Exhaust Manifold
Exhaust Manifold Hardware
Google the Walker part numbers fir a better price.
Does it need y pioe from Exhaust Manifolds to muffler?
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Keep each post limited to one issue.
I gave you source for tbe 87 diagrams in your other post. They are same as in Ford's shop manuals and EVTMs.
I merged your other post because the year and model were missing.
Google 1984 Bronco Electrical and Vacuum Troubleshooting Manual (EVTM)
Results:
http://www.autobooksbishko.com
Ford authorized publisher
EBay; http://www.ebay.com/sch/i.html?_odkw=Ford+Bronco+EVTM&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.XFord+Bronco+EVTM+Shop+Manual.TRS1&_nkw=Ford+Bronco+EVTM+Shop+Manual&_sacat=0
http://www.ebay.com/sch/i.html?_odkw=Ford+Bronco+EVTM+Shop+Manual&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H1.XFord+Bronco+Shop+Manual.TRS1&_nkw=Ford+Bronco+Shop+Manual&_sacat=0
both suggested by Seabronc @ http://broncozone.com/topic/5561-electrical-or-vacuum-troubleshooting/
Another result is http://www.auto-repair-manuals.com/cgi-auto-repair-manuals/sb/ss_mb.cgi?storeid=*2aa6462b339608c8a84e386e06e024d2c1c4fdbb8e1558&ss_parm=A2848b0e702c0ebfd464963ebe4caa16b&gclid=CjwKEAjwtbPGBRDhoLaqn6HknWsSJABR-o5s1C22rdxGcYDExaec7bg0gTawtdt2Psp0iwQElZiLPRoCgpbw_wcB
Seabronc may have some diagrams for you and a carb recommendation.
I do have this, but it needs to be validated with an EVTM:
"TSB 87-15-3 1980-88 F-SERIES, BRONCO, etc. Corporate Standard Circuit Number Charts for Wire Circuit Number, and Color Codes;
pinpoint individual circuits, use these charts with the appropriate Shop. Manual, EVTM."
https://www.google.com/url?sa=t&source=web&rct=j&url=http://www.revbase.com/BBBMOTOR/TSb/DownloadPdf%3Fid%3D21412&ved=0ahUKEwi11qfJluHSAhXC4iYKHeR8Cr44ChAWCBswAQ&usg=AFQjCNHmCW72e0sUKpA-6tZ3d5oPQS6-dA&sig2=R8FNuU7HNF6WCnrrotgySQ
orogopher
Claremont,Calif
Yeah I do from fords shop manual....what year..years you looking for....not sure how to set up a link for you with pictures that I can take....but my email is,[email protected]
If you send me your email if you have....I can send you pics of diagrams you need....or as I just seen I can share them onto Facebook.... Your call
Sgariffo
