Yo Mike,
A test of the EEC system is conducted with the engine running. The sensors are checked under actual operating conditions and at normal operating temperatures. The actuators are exercised and checked for expected results. So you will here sone clicking as they perform their calisthenics. The CEL should go out until:
Engine Identification Codes (ID Codes)
Engine ID codes are issued at the beginning of the Engine Running Self-Test and are one-digit numbers represented by the number of pulses sent out. For gasoline engines, the engine ID code is equal to one-half the number of engine cylinders (i.e. 2 pulses = 4 cylinders). For the 7.3L Diesel engine, the ID code = 5. These codes are used to verify the proper PCM is installed and that the Self-Test has been entered.
Dynamic Response Check
The dynamic response check is used on some applications to verify operation of the TP, MAF, MAP and KS sensors during the brief Wide-Open Throttle (WOT) performed during the Engine Running Self-Test. The signal for the operator to perform the brief WOT is a single pulse or 10 code on the STAR Tester.
Power Steering Pressure (PSP) Switch Test
On vehicles equipped with Power Steering Pressure (PSP) switch, the steering wheel must be turned one-half turn and released AFTER the ID Code has been displayed. This tests the ability of the EEC system to detect a change of state in the PSP switch.
Brake On/Off Test
On vehicles equipped with Brake On/Off (BOO) input, the brake pedal MUST be depressed and released AFTER the ID Code has been displayed. This tests the ability of the EEC system to detect a change of state in the Brakelamp Switch.
Transmission Control Switch (TCS) Test
On vehicles equipped with E4OD TCS, the switch must be cycled after the ID code has been displayed. This tests the ability of the EEC system to detect a change of state in the TCS.
Have you previously used this reader?
Read koer procedure by BronvcoJoe
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Scan Tool Won't Initiate Self-Test Due to Poor Grounds, Corroded Wiring, etc.;
Source: by Jeremy M (Big '92, jermil01)
For that 12" section that broke, can u pick it out from this diagram?
I am guessing its the Front Stabilizer Bar (sway bar) Link; hereare pics by rugerp89ipsc:
If it is, remove it. Or purchase what you need from a yard queen or parts store.
http://www.diesel-dave.com/vehic/manual/stj/images/f7714c.gif
Item Part Number Description
1 5K483 Front Stabilizer Bar Link
2 N620482-S36 Nut, M12 x 1.75 Hex ******
3 5482 Front Stabilizer Bar
4 3B353 Retainer, Stabilizer Bar, Front
5 5484 Insulator, Stabilizer Bar, Front
6 N806789-S2 Bolt and Retainer, M10-1.5 x 33.5 Hex
7 N605704-S2 Bolt, M12-1.75 x 65 Hex
8 N620469-S2 Nut, M12 x 1.75
9 N801527-S2 Washer, 13 x 34 x 2.5
A —Tighten to 72-108 Nm (53-79 Lb-Ft)
B —Tighten to 34-46 Nm (25-34 Lb-Ft)
http://www.diesel-dave.com/vehic/manual/stj/images/f2856p.gif
1 3B008 Steering Rod Link
2 800895 Nut
3 642569 Cotter Pin
4 380288 Steering Cap
5 801079 Bolt
6 3002 Axle
7 5019 Front Crossmember
8 620604 Nut
9 802073 Nut
10 802114 Bolt
11 802246 Bolt
12 802073 Nut
13 620604 Nut
14 801079 Bolt
15 3K090 Front Axle Bearing Bracket
16 802210 Bolt
17 3B183 Radius Arm Bracket
18 800937 Nut
19 34922 Nut
20 379572 Washer
21 2B463 Shield (RH Only)
22 3A184 Outer Insulator
23 3B244 Spacer
24 3B203 Front Insulator
25 3B186 Front Retainer
26 3405 Radius Arm
27 N805348 Nut and Washer
28 18198 Insulator
29 5B315 Spring and Shock Bracket
30 18124 Front Shock Absorber
31 620468 Nut
32 620469 Nut
33 18126 Shock Bracket
34 805033 Bolt
35 3405 Radius Arm
36 605921 Bolt
37 58740 Bolt
38 3B446 Front Axle Radius Arm Bracket
39 40954 Bolt (2 Req'd)
40 390678 Stud
41 5B316 Lower Spring Seat
42 5414 Front Spring Insulator
43 5A349 Retainer
44 388833 Nut
45 5310 Front Coil Spring
46 5A333 Upper Retainer
47 40949 Bolt
A —Tighten to 71-100 Nm (52-74 Lb-Ft)
B —Tighten to 18-24 Nm (13-18 Lb-Ft)
C —Tighten to 34-46 Nm (26-33 Lb-Ft)
D — Tighten to 60-81 Nm (49-59 Lb-Ft)
E —Tighten to 434-461 Nm (320-340 Lb-Ft)
F —Tighten to 26-34 Nm (19-25 Lb-Ft)
G —Tighten to 326-352 Nm (240-260 Lb-Ft)
H —Tighten to 94-134 Nm (70-100 Lb-Ft)
J —Tighten to 34-46 Nm (26-33 Lb-Ft)
K —Tighten to 113-153 Nm (84-112 Lb-Ft)
L —Tighten to 213-287 Nm (157-211 Lb-Ft)
M —Tighten to 104-148 Nm (77-109 Lb-Ft)
http://www.diesel-dave.com/vehic/manual/stj/images/g8989b.gif
1 3A131 Tie Rod Ball Stud
2 3310 Front Wheel Spindle Tie Rod Adjusting Sleeve
3 3304 Steering Sector Shaft Arm Drag Link
4 — Drag Link Ball Stud (Part of 3304)
5 3A131 Tie Rod
6 N800895-S56 Nut
7 3590 Steering Gear Sector Shaft Arm
A — Tighten to 70-100 Nm (51-73 Lb-Ft)
Or snap a pic
