I replied a few secs ago at
http://broncozone.com/topic/25740-battery-drain-fuse-12-is-drawing-power-when-truck-is-off-please-help/?do=findComment&comment=135457
But you wrote there, "So we found the draw, here is what it is, we double and triple checked and are 100% certain this is the issue. The clicking noise came from the AC clutch engaging, when the **** is set to vent, defrost or ac it will engage the clutch with the vehicle off, this is what was drawing the power, when the **** is set to off there is no engaging of the clutch and no power draw. I find it incredibly strange that this was somehow tied in fuse 12 CB. So now I need help tracking down the ac clutch engaging with the vehicle off."
So now, read what I wrote there, especially, An A/C clutch (2884) is energized when the A/C cycling switch (19E561), located on the suction accumulator/drier (19C836), closes. The closing of the A/C cycling switch completes the circuit to the A/C clutch and draws it into engagement with the compressor driveshaft."
*** FOR now, SUSPECT The A/C cycling switch. ***
The A/C cycling switch is mounted on a Schrader valve fitting on the side of the suction accumulator/drier assembly. A valve depressor, located inside the threaded end of the A/C cycling switch, presses in on the Schrader valve stem as the A/C cycling switch is mounted and allows the suction pressure inside the suction accumulator/drier housing to activate the A/C cycling switch. The electrical contacts will open when the suction pressure drops to 163-175 kPa (23.5-25.5 psi). They will close, activating the A/C clutch (2884), when the suction pressure rises to 276-324 kPa (40-47 psi). Lower ambient temperatures (below approximately 1°C (30°F) during cold weather seasons will also prevent A/C compressor operation, because of the pressure/temperature relationship of the refrigerant in the system.
NOTE: Temperature must drop to -4°C (25°F) to open pressure switch contacts. Contacts open at approximately -4°C (25°F) decreasing and close increasing 7.2-10°C (45-50°F).
The electrical contacts control the electrical circuit to the A/C clutch field coil. When the contacts are closed, the A/C clutch field coil is energized and the A/C clutch is engaged to drive the A/C compressor. When the contacts are open, the A/C clutch field coil is de-energized, the A/C clutch is disengaged and the A/C compressor does not operate. The A/C cycling switch, when functioning properly, will control the pressure at a point where the plate-fin surface temperature of the A/C evaporator core will be maintained slightly above freezing which prevents icing and the blockage of airflow.
Clutch Cycling Pressure Switch Connector Location in Engine Bay Diagram in a 95
Source: by SeattleFSB (Seattle FSB)
Switch depiction:
http://www.diesel-dave.com/vehic/manual/stj/images/m2748d.gif
Item Part Number Description
1 19C836 Suction Accumulator/Drier
2 19E561 A/C Cycling Switch
3 19D734 A/C Manifold and Tube
4 19D607 A/C Accumulator Bracket
