Yo cableguy,
Some info by 80-96 Bronco owners;
lariat06's wrote "I changed mine to 17" Lightning wheels and went with 265/70-17 Yokohama A/T's . No clearance problems at all and it seems to work well of road as well as smooth highway driving." 96 XLT 5.8 265/70-17's 3.55's T-Loc rear.
hopp150 wrote "I have 285x75x16 on 16x8's with no problems at all. 3.75 backspacing did the trick for me." 1996 Eddie Bauer
5.8L, 2.5" Rough Country.
huggyb1972 wrote, "
265/75-16's fit without an issue my 90 had them when I bought it. Black rock rims look to pretty good"
Sock Puppet wrote, "I'm considering the same thing, but I want to use a 265/75 16 which is very close in overall size to a 31X10.50 15. I'm leaning toward a 16X8 wheel, but haven't decided for sure yet. 1996 XL, 5.0,
Hummer H1 Modification & Installation in an 94
Source: by our late friend here, justshootme84 (Randy Z, Casual Mudder).. RIP Randy; at
http://www.supermotors.net/clubs/superford/registry/1133/57018-2
Recentered H1 Wheels Fabrication in a 90
Source: by Dave's Bronc 90 (Dave B) at
http://www.supermotors.net/registry/7660/62914-2
"...Dodge 16" rim can be made to fit a Ford..." read pic captions @
http://www.supermotors.net/registry/media/744829
Backspacing is very critical;
http://www.4wheelparts.com/tire-wheel-package-guide/wheel-offset-backspacing.aspx
http://www.therangerstation.com/tech_library/Gear_Tire_RatioChange.shtml
Tire Circumference Differences, Could Cause Pulling Problems, Ford 4x4; "...One that I've heard of through Ford sources is measuring the circumference of the rear tires and comparing them to each other. Tires, if it's a four-wheel drive, the four tires need to match. I know that sometimes it's a real tough sell to tell a customer that this is what he needs before you can accurately diagnose the problem, and sometimes you have to do the best you can with the hand you're dealt. But we all have dealt with the reality that even a set of high quality new major brand tires can affect vehicle..." Miesk5 Note; Do not just compare tire sidewall labels, you must measure each tire across the center of the tire. With Bronco jacked up on the corner being measured. A stagger gauge will let you do this with the vehicle on the ground in 5 minutes. The other way to measure cirumference while still on the Bronco is to mark the tire & surface with chalk at the bottom of the tire, and then roll forward until the mark is at the bottom again & mark the ground there; measure the distance between the 2 marks on the surface, and divide by 3.14 to get your diameter.The tires must match in diameter to .250". Source: by northstarmfg
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
