About to replace rockers in my Bronco
FordER
Hi everyone,
I am new to your guys Bronco community, but am not new to Ford Bronco. Mine is 1995, and I thought to do something about its exterior, as with years some parts corroded (moisture, rock chips and road salt do their job). So, wanted to start with the rockers, as they are the ugliest, to my mind, as they're rusty. I was about to get the two rockers in, and wanted to ask you about the installation. You cut the old ones off and WELD the new ones, right?
Thought ,maybe there is another way to get them installed, maybe bolt-on? Or that's a bad idea?
Thanks, any help's highly appreciated!!!
Yo FordER,
Welcome to the Zone!
We've been battling that wheel arch rust for a few years now too. The inner fender is spot welded to the outer 1/4 panel and this method causes all the 1/4 panel rust problems;
The usual practice is to cut out the entire 1/4 panel & weld in a new piece; or replace the wheel arch section.
Quarter Panel Repair on an 85 by Chris B (Blue) at
http://web.archive.org/web/20041027164302/http://chrisb.users.superford.org/Projects/the_rear_quarters.html
Alternatively is to use body adhesives in lieu of welding.
Replacement w/adhesive in an 86 by Sixlitre (Malcolm H, Eddie Bauer) at http://www.superford.org/registry/vehicles/detail.php?id=4970&s=19605#content]
Malcolm used an Astro Pneumatic 3/8\" Spot weld cutter.
Site is slow
to save $ on a compl 1/4 panel, I bought the 1/4 panel patch panels. They are primed and of 18 gauge steel - exact fit around wheel well arch and packaged very well for shipping.
90-87-52-LH LH left hand (driver side) Upper Wheel Arch Area, that fits pickup or Bronco. $23.10 each
http://www.rustrepair.com/PANELS/FORD-BRONCO-REPAIR-PANELS.HTM
I ordered it on 6 JUN 2011 @ 1225 hours and received on 8 JUN 2011 !!! S & H cost for both from Cleveland, OH to NJ was around $12.00.
Fits from the horizontal crease below camper top down to wheel arches and around the arches, exact fit. Was able to weld w/no adjustments to it or the 1/4. Can be attached w/body adhesive or even PL Premium; Sixlitre has been experimenting w/PL Premium on some parts.
Of course, cut the rusted arch section out and inner panel. so you can inspect and clean higher up inside 1/4
Patch Panel Installation, Jeff's Bronco Graveyard in a 94
Source: by R94BroncoXLT (Ryan) at http://www.superford.org/registry/vehicles/detail.php?id=4853&s=21778#content
Site is slow
Some have used LORD Fusor® 108B/109B metal bonding adhesive is specified for use by General Motors, Ford Motor Company and Nissan. It can be used for panel bonding,weld bonding and rivet bonding of properly prepared metals, including aluminum.
MIG Welder, Lincoln Electric, Setting for Body Panels pic; "this is the perfect setting for sheet metal work---with 35 CFM of Ar/CO2; he shows slightly less than 2 and on E in the pic..."
Source: by mickaila
Replacement w/adhesive w/parts list; including wheel house in a 90; Panel Adhesive, $26.00 a tube & Application Gun, $65.00 by wheelersautobody.com , etc.
Source: by Jason T (Broncomx, Two Face)
Wheel Arch Fabrication, Fiberglass in an 86 (left click mouse & drag over to view narrative)
Source: by Matt J at TheBronco.com via
http://web.archive.org/web/20050306183552/http://www.thebronco.com/projects/pr0201.html
AutoFab - Bronco/Ford truck/Ranger fiberglass fenders (& "Ashley style"), hoods, quarter panels, tailgate for 92-96; engine mounts for 80-96; 9" skid plates; 9" skid plate; pre-runner bumpers (92-96 Bronco/F150 w/skid plate; 89-91 w/out); Mastercraft racing seats; 80-96 Bronco/F150 4" front lifts for 16" wheel travel; Bronco/F150 rear lifts for 16" & 18" wheel travel
http://www.autofab.com
McNeil Racing, Inc. & Perrys Fab n Fiber - 73-96 Bronco/Ford truck fiberglass fenders, hoods, quarter panels; one piece fiberglass front end for 80-96 Bronco, 73-79 Bronco Conversion to 96 Bronco, 92-96 off road & OEM style fiberglass & carbon fiber dashes with built-in center console (same as FiberwerX dashes)
http://www.mcneilracinginc.com
For extended spot weld cutter life;
Rotabroach Stick Lubricant is specially formulated for use with Blair tools.
Increases tool life and cutting speed.
Apply directly to the tool before cutting. A waxy type lubricant that melts and provides lubrication to the cutting teeth.
or;
use a light machine oil, WD40, motor oil, etc... clean the area before installing new panel & painting etc.
FordER
FordER
Thank you for such extensive reply! Though the archs were replaced a couple of years ago. And now the ugliest parts are those rockers. So I guess I will cut out the rusty part, and then will have to weld the new ones in (https://www.carid.com/replacement-rocker-panels/).
Yo FordER,
YW! But thanks really goes to Sixlitre and the others who took the time and effort to document their work.
Forgot to mention that in Supermotors, to view any narrative, under Sixlitre's name in upper left, click Select Alternate View; clicK Thumbnails + Captions.
Next time, please fill out your Signature with year, engine size, transmission type, transfer case type (manual or electric shift), locking hub type (automatic or manual) info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
Our sponsor, Jeff at the Bronco Graveyard has offered a 2% discount to members of The BroncoZone for on line orders. To get your discount, enter the discount code BZMEMBER. Also you must include your BroncoZone User Name with the order.
http://broncograveyard.com
Here are some wiring diagrams (partial, 86 through 96) and Technical Service Bulletins, (80 through 96) @ http://www.revbase.com/BBBMotor/Wd
1995 Bronco Dealer Brochure by Ford via me @ http://www.supermotors.net/registry/3549/79188
topless92
If you do weld then in just from my experience weld a tack here n then move to a different section n tack it and keep moving around you don't want to much heat in one spot it will warp
Sgariffo
