Turn Signal Issues
jmw7620
The turn signals on my 79 bronco stopped working and I'm having trouble figuring out how to fix them. The park lights, brake lights,headlights work fine. But nothing from the turn signals and now the emergency flashers work only on the right front and left rear when activated. I've changed all the bulbs, the flasher modulator and the fuse....any other ideas on next steps for trouble shooting would be very helpful.
Yo jmw,
Check for corrosion in socket. Clean contacts.
1979 Bronco Electrical and Vacuum Troubleshooting Manual (EVTM) by Ford via topsig @ http://www.supermotors.net/registry/24302/83503
Turn Signals begin @ file #20
Ground Locations shown on #21
Description and Troubleshooting on #22
Although not mentioned in this document, the emergency flasher is on back of fuse panel. Woody wrote here, "...its on the opposite side. pain in the but to get to mine feel back there if you find it you may have to pull the fuse assy..."
Fuse Block;
