Wheel swap fit..?
Vegas Vic
Hello, I'm not sure if I'm in the correct spot to ask this question, Please forgive me if I am.
I currently bought a 1970 Bronco and found a set of used wheels and tires I'm interested in purchasing for it.
The wheels are currently on a 2014 F-150. Can someone inform me if the bolt pattern is the same?
Hi Vic..,  welcome..!
Ya., its best to click on "start a new topic"
The Early Broncos are called out as 5 on 5 1/2     i.e. 5lugs  and  5 1/2 inches from one lug to (skip one) that next lug.
The lug holes may be the same but the way the lug nuts lock down may be different.
Also.., the center hole may be different.., as well as the "backspacing"..!!
All this is very important for safety.   (looks should be last priority)
Check with your local tire shop.
ALSO.., disc brake wheels are usually different.
Utahstroke
