My first Bronco
BroncoChris
Hello guys. I purchased a Bronco about 3 weeks ago. I picked it up for 650 bucks running and driving. Id like to post some pictures for you all to see them.
Yo Chris,
What year did you purchase?
please fill out Signature with year, engine/tranny/Xfer case/hub type info & major mods such as a Lift, etc. for better responses.
Click your name in right black panel in upper right;
In pop up,
Click, My Profile
Click, Edit My Profile in right side black panel
In left panel, Click, Edit Signature
Enter info
Click, Save Changes
To post a pic from your PC, TABLET, etc., just below the reply box in lower right corner, click More Reply Options
Screen will change
See Attach files
pick out the pic
Click Attach This File
or click, Try our advanced uploader (requires Flash 9)
BroncoChris
The year i got is a 1991. When i bought it, she ran but a slight miss fire. Turns out that it was a fuel injector. I replaced the injector and now running great lol
BroncoChris
Having a little trouble posting pictures. Says file to large so i gotta figure this out
Gr81ness
Hello all,
I just purchased a 1990 Bronco, my first one. I've always loved their combo of style and power. I live in a crowded city but am only 2 mins from work. I was told it needs brakes all the way around so taking care of that tomorrow. Runs and shifts great so far. Only 135k miles on it. Thought it was a steal at only $700. I read about the steering box issues but if a little play is normal, I might be good for a while. I'm sure I'll be posting about any potential problems. I'm glad there is a website such as this :) /emoticons/[email protected] 2x" width="20" height="20" />
Thanks
Yo Gr81ness,
Welcome to the Zone!
That is a good buy!
Post some pics when you can, see what I wrote to Chris, above.
FYI, 1990 Bronco Pre-Delivery Shop & Electrical & Vacuum Troubleshooting Manual (EVTM), Partial by Kingfish Google Drive @ https://drive.google.com/drive/mobile/folders/0BzRTW4yeT2u4UkhzR0ZydDd3MzA?usp=sharing&tid=0BzRTW4yeT2u4NXB6NW5neFRoZGc
Slow scrolling.
Find page # of item desired in contents, then flip screen flip down like spinning a bearing then stoping perioically to see what page you are now on.
GL!
Pick out your steering issue @ Symptom Chart — Steering System Problems
http://www.diesel-dave.com/vehic/manual/stj/stjb0003.htm
It's for a 96, but similar.
If you want to discuss this further, enter a new post in the 80-96 Ford Bronco Tech Support section.
96 is same as most earlier years, except for:
96 uses the OBD-II (EEC-V) engine management computer;
Anti-Lock Brake
4 wheel is 4WABS (93-96);
Rear is RABS (87-92);
Air Bag (94-96);
3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
R134a in 94-96;
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD;
Mass Air Flow in 95 5.8 California models and in all 96s, other years used Manifold Absolute Pressure Sensor (MAP).
Still researching other differences.
Sgariffo
