74 Bronco no power
Florida Bronco
I've replaced several things over this past year including
Battery
Solenoid
Starter
Ignition switch
Neutral safety switch
Alternator
Fuses/relays
Before it stopped working and i mean nothing has power the ignition fuse has been popping over the past few months because of a power overload somewhere but I'm not sure where because it started happening out of nowhere and now I have no power
The wiring is older but in still fair shape with a Centech fuse panel Easy fix or not I don't know what to look for I'm going to attempt to check grounds but I'm unsure what to look for Carpenter not Mechanic
I suspect that you have a wire that has rubbed through the insulation where it either passes through a panel or is lying against metal.  Unfortunately, I don't have a circuit diagram for you.  You can trouble shoot the problem by replacing the fuse with a test light and then follow the circuit till you find the problem.  The light will go out when you find the short.
Another thought;
Centech fuse box indicates a "re-wire" was done. Look on the wires., they will have their location printed
on them in very small print.
If so, check the terminal ends.  On one EB I found some that were loose & some would pull apart. (re-crimped)
Ign. (circuit) fuses blowing is suspicious. Is the voltage regulator puting out the proper voltage.?
Below is for '67  There may be some slight differences.., wire coloring may be diff. as well.
Utahstroke
