1977 dana 20
chillydog
Virginia
Just finished a rebuild on my 1977 dana 20 T-case and i think something might be wrong.  When i place the case into 2WD only the front yoke engages. The rear spins freely. 4 HI and 4Lo appear to be fine.  I have no clue what i did smh
Anybody ?
Can you clarify a bit...?  Sounds like the drive shafts aren't on yet..? Or R U bench testing ..?
RU sure the 2 shift-shafts are in the correct position..?
You should feel the ball/spring drop into the indent.
OUCH..!   I would have suggested the mod. & rid of that "J" shifter for a "twin-stick" shifter
beings the D-20 is on the bench.
My "T" shift works fine but I'm tempted, at times, to go with the twin-stick.
C
chillydog
Virginia
if i was planning on keeping it i would have gone twin stick.  But since its restoration i opted for stock.
Hmmmmm.., RU 100% SURE you're shifter is working correctly & you're in the right slots/indents
at the correct time..?
Tried taking the shifter off & shifting by hand...??
A shame to have to gut it again.
genthree (on this board) did his...., PM him, maybe he can help.
genthree
Medford, OR
Chilly dog-  Did you get it figured out?
I did mine and I was able to index the shift rods with the cover off and watch what was going on...  If you need pics of how it should look, mine is open on the bench right now.  My D20 is a PITA to shift, so you may think you are in the right spot but with a little extra force it will move again for you.
Really easy to see if you pull the cover off....
PS...  I am  going to ditch the T shift and go to a twin, because I HATE fighting this thing....
