Yo Justin,
Are you using a code reader or did you do the self test by BroncoJoe19?
The number 40 is not a DTC, it is most likely from the Cylinder Balance Test;
-Immediately after all KOER codes have been output, a quick tap of the throttle will initiate the cylinder balance test.
-The codes shown are of a slightly different format, that is, they are multiples of ten. 10, 20, 30, 40, etc. for example 4 flashes would equal 40.
So, Cylinder #4 Failed Cylinder Balance Test.
Check for usual suspects; loose/bad spark plug or wire @ plug or @ distributor, or distributor terminal fouled or carbon tracks inside cap, etc.; then inspect cylinder 4 injector connector, mine loosened due to a squirrel dinner.
BTW;
I believe there is only one O2 sensor on your 90 and it is on passenger side (bank 1).
HEGO (O2 sensor) Connector C114 Location Diagram in a 90 by Ford via Seattle FSB
More diagrams @
http://www.supermotors.net/registry/20487/76450
Such as HEGO Ground,
Ground Locations in a 90 from 1990 Bronco EVTM; G100 LH side of Radiator support G101 RH side of Radiator support G102 RH side of Radiator support
*** G103 LH rear side of engine, near knock sensor ***
G104 LH rear side of engine compartment, near electronic engine control (EEC) module, on the left fender close to the firewall G105 LH Side of engine G106 RH fender apron, near voltage regulator G107 RH fender apron, at starter relay G108 RH fender apron, at voltage regulator G109 RH fender apron G201 LH rear side of I/P (looking at the diagram it is at the bottom of the driver's side dash assembly. Screwed to the bottom edge, just to the left of the steering column. It is the ground for the instrument cluster) G202 Behind RH cowl panel G203 RH rear side of radiator support G204 On steering column G205 Behind Center of I/P (Dash), near speed control amplifier G400 LH side of cargo area, near rear light assembly G401 Below LH side of cargo area, near crossmember G500 Inside driver's door, near left door speaker.
by our pal
by BroncoJoe19 (Joe) at Ford Bronco Zone Forums
