1978 Bronco Ranger XLT help
Kingnoff29
Westminster Colorado
Well to start off I recently inherited my late grandfather's 1978 Ford bronco it has the 6.6l 400 cid v8 it was rebuild back in 1988 when a bearing spun in the crank well needless to say it's been sitting sense then. Sense it has only 72026.9 original miles I want to keep it that way. So I am looking for the egr plate and a motorcraft 2150 2bbl and maybe some help putting everything back together. If there is anyone in Colorado that can help.
2150 carbs are very common/available.  As are egr parts.
After it's runn'n..., go thru the brakes to be sure it "stops"...!
Best to ask your questions in the  '78-'79 tech support section (above)
Staff online
Fryman22
