Yo Jon,
Our 96, bought new has its original muffler. It has a "weep" hole for condensation to drain while engine heats up to normal operating temperature.
return the Amazon Tester to save $. Get one from local parts stores in a loan a tool program... refundable deposit for the pressure tester ...
Coolant drains to the bottom of the radiator where it flows out thru the lower radiator hose to the water pump inlet. The pump then forces the coolant into the block, where it flows around the cylinders to the back of the block. Passageways cast into the cylinder block (6010) and cylinder heads (6049), which allow coolant to circulate and absorb excess heat so that engine parts are not damaged by excess heat. Within the head(s) is where the coolant reaches its highest temperature, which is why all coolant sensors are near the head(s). In V8 engines, the coolant flows into a crossover journal in the intake manifold before diverging; in straight 6 engines, it diverges from the head either thru the t'stat or into the heater outlet. In either case, this is generally where its temperature is detected by both the sensor for the gauge & by the engine coolant temperature (ECT) sensor for the PCM (EEC).
Some V8 engines also have a bypass hose which allows coolant to return directly to the water pump. There also is a small circuit to the throttle body for de-icing, which typically returns to the radiator upper tank.
Coolant Line From Radiator to Throttle Body; "...Top hose goes to the filler neck, bottom is the coolant source from the metal fitting that screws into the intake manifold (look where the heater hose and ECT sensor go, there's a 3/8-inch ****** on it)..." Source: by SigEpBlue (Steve)
Coolant Line From Radiator to Throttle Body; "I was just in the dealership yesterday and had them order me one as mine is old and looking tired. They said they can still get it and there is a 20" and 24" mounting tab version. My 90 is the 20". Figured I had better grab one before they disappear and I have to fab my own (cheaper, but I want the factory part). The part number for the coolant line that runs on the radiator is F2TZ8555B (20") and runs about $61 bucks. Got lucky with the water outlet/fitting that comes out of the lower intake manifold that goes to the the heater core and has a port for a temp sensor and line for the coolant into the TB as they still can get this as well and I replaced a leaky one last fall. Pricey for sure, but you pay for stock old stuff I guess." 20" would be a 2 core radiator,
24" would be for a 1 core radiator.
Source: by mbastianel in a 90 Bronco
Coolant Line From Radiator to Throttle Body Fabrication & Installation pics in a 96 :...Here's the photos of the Gates transmission cooler line I used. I also used Oetiker stainless smooth inside crimp clamps. I think they were 21/32" diameter = 16mm. Which is what the 162 mark on them is for....16.2mm. In the photo it looks like its close to the alternator pulley. But its not. 2D photo in a 3D world.
/emoticons/
[email protected] 2x" width="20" height="20" /> It just runs across the top of the radiator and makes a loop over by the fill neck. The last photo is the short one from the water outlet on the intake to the bottom of the throttle body. Not very expensive either. I think $8 worth of hose. Its pretty high temp stuff...and good to 400psi. My cooling system doesn't quite get to 400 psi..."
Source: by 3speed at
http://www.supermotors.net/registry/22641/74821
ECT = engine cooling temp sensor which threads into the "octagonal" tree shaped tube that's threaded into the lower intake manifold and has a small TB cooling tube and hose AND another metal tube/hose threaded into the side which goes to the heater core inlet IIRC.
https://s3.amazonaws.com/2cp-images/question_images/1778/large.JPG
http://www.supermotors.net/getfile/782138/fullsize/what-is-this-2.jpg
This "octagonal" tree shaped tube is available at RockAuto Mobile Catalog
1990 FORD BRONCO 5.8L V8 MOTORCRAFT KT81
http://www.rockauto.com/info/48/E8TZ18B402C-BAC.jpg
{#E8TZ18B402C} HVAC Heater Pipe Tube to manifold
1992 FORD BRONCO 5.8L V8 : for example
Heat & Air Conditioning : Heater Hose / Pipe
MOTORCRAFT KT81 Click for more information about this part
{#E8TZ18B402C} HVAC Heater Pipe, Tube to manifold $48.79
Coolant that exits the t'stat flows thru the upper radiator hose into the top of the radiator & thru the core where heat is radiated into the airstream. The cool (lower) radiator tank may contain the upstream fluid cooler for the automatic transmission, and the lower radiator hose may contain an orifice which diverts some coolant to the engine oil cooler if equipped.
Coolant recovery reservoir, which holds surplus coolant. When the system is hot and coolant expands, coolant goes into coolant recovery reservoir. When the vehicle cools, the system draws coolant back into the radiator, eliminating the need for frequent topping-off of the cooling system. The coolant recovery reservoir eliminates the loss of coolant through an overflow tube.
Pressure-vacuum radiator cap, which allows coolant to escape to coolant recovery reservoir when it expands so system pressure does not build, possibly bursting a hose or radiator tube. The radiator cap allows coolant to be drawn back in from coolant recovery reservoir when system cools, refilling system and preventing hoses from collapsing from a partial vacuum in system. The pressure-vacuum radiator cap also maintains 90kPa (13 psi) pressure in the cooling system. Pressurizing the cooling system raises the boiling temperature of the coolant allowing more efficient higher engine temperatures and reducing the risk of boiling over when driving at high altitudes.
Engine cooling fan, which draws air through the radiator to help cooling at low speeds or when the vehicle is not moving. The system is designed so that air forced through the radiator by the forward motion of the vehicle is sufficient at driving speeds.
Fan clutch (8A616), which decreases engine power needed to drive fan by allowing fan to free-wheel when engine is cold or when vehicle motion forces air through the radiator. The fan clutch has a thermostatic control so that it drives the fan when the engine is hot and air flow from the vehicle's motion is insufficient.
Drive belt (8620), which drives the water pump, fan and other accessories off of engine crankshaft (6303). Refer to Section 03-05 for more information on drive belt.
Engine transmission fluid cooler (7A095). On vehicles with automatic transmissions, a provision is made for cooling the transmission oil by circulating running it through a cooler in the radiator.
The lower radiator hose flows TOWARD the engine.
The upper hose flows AWAY from the engine.
The heater hose connected to the intake manifold or t-stat outlet flows AWAY from the engine.
The heater hose connected to the water pump flows TO the pump.
The little bypass hose on V8s flows TO the pump.
The metal line on the radiator flows TO the radiator.
Hot coolant flows OUT of the head or intake manifold. By Ford via Steve with modifications by me.
CHECK THERMOSTAT OPERATION
Allow engine to run for 10 minutes.
Feel the inlet and outlet heater water hose and the underside of the upper radiator hose.
Are the upper radiator hose and heater water hoses cold?
Yes REPLACE thermostat.
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some basics;
Do KOEO test First
KOEO
KOER
GL!
