Yo New2bronco,
For a ba**s to the wall swap, depending on transmission type and/or Emissions laws on carburetor swap:
Engine Conversion Kits for Bronco & Ford Trucks (sales catalog w/pics & descriptions) @
http://www.landlproducts.com/catalog.pdf
Examples:
1980-96 TRUCKS AND BRONCOS 2WD AND 4WD
EQUIPPED WITH 6-CYLINDER ENGINES AND C-6
AUTOMATIC TRANSMISSION CONVERTING TO
429/460 ENGINES.
BASIC KIT INCLUDES:
PART NO. DESCRIPTION
040425 RUBBER MOUNTS WITH STANDS SET 429/460 ENGINE
040500 7-QT. BAFFLED OIL PAN KIT REAR SUMP
10156B ALTERNATOR MOUNT AND DRIVE KIT
10145C POWER STEERING MOUNT AND DRIVE KIT C-II PUMP
79760A 429/460 ULTRA FLOWTM HEADER STD. HEAD CHASSIS EXIT
040183 90 DEGREE REMOTE OIL FILTER SYSTEM
260561 SUPER COOLING RADIATOR (1980-83 VEHICLES)
OR SADDLE MOUNT
260562 SUPER COOLING RADIATOR (1984-96 VEHICLES)
CORNER ****** BOTTOM PIN MO...etc.
300 (4.9L) Rebuild in a 78
Source: by chebbykiller (*********, The Bronco) at
http://www.supermotors.net/registry/16969/59660-4
Includes for Example:
Offenhauser Dual-Port aluminum, 4bbl intake manifold.
She now displaces 304.6 CI.
http://www.shop.cliffordperformance.net/Ford-240-300_c3.htm
Camshafts:
Clifford Performance
Crower
Crane
Comp Cams
Lazer Cams
Accelerated Motion
ultraDyne
Blueracer
Schneider Cams
Iskanderian
Header:
MAC
Dynomax
Pace Setter
Hedman
Intake:
Offenhauser
Edelbrock
Hogan
"The EFI stock headers are about as good as any short-tube header. Not recommended in replacing them unless your after some serious power. 302 is the throttle body of choice. AOD weighs just about as much as the C6, so stick with it because of the OVERDRIVE. Unless your doing some major hauling or a torque monster 300, you don't need the C6. ENSURE TV Linkage is Adjusted with a pressure gauge tapped into the side port of the transmission...." by Guest
https://web.archive.org/web/20070327105659/http://www.tciauto.com/Products/Instructions/instructions/431000_inst.htm
Chapter 9, from Ford Fuel Injection and Electronic Engine Control: How to Understand, Service and Modify, 1988-1993
http://www.yunost.ru/docs/Ford-injectors-book/Part09/Part09.pdf
