351w heads
Eskiltell
Hi guys. I got a '91 with 351w. I need to fix the exhaust manifold bolts, there areally a few stripped holes. I'm wondering if I buy '95 351w heads if I can just bolt them on and they'll work, or I can drill the current holes and tap them for a larger bolt or helicoil them. Thanks!
E
Eskiltell
That's what I'm thinking. The heads I was going to put on have rusty coolant tunes or whatever they're called. Do you know what helicoil kit I should get?
Not off hand, it is based on the bolt and hole size.  A parts shop should be able to suggest the right set.
MaximusBronk
Texas
Helicoil the holes, and replace manifold with JBA headers.  If going with the headers, be SURE to put spark plug heat insulators on plug heads.  Been there, done that....
Rod
Utahstroke
