Bronco grille
Dirtroadmode
Does anyone know, Will the grille from a 1995 f-150 fit a 1995 bronco? I have found a custom grille and I hope I can use it.
Yo Dirtroadmode,
Yes it is a direct fit. All 92 to 96 grilles F Series and Bronco grilles are interchangeable.
Removal
Open hood (16612).
Remove three screws securing radiator grille (8200) to front valance panel (17626) from the front of the vehicle.
Remove four screws from the top of the radiator grille securing the radiator grille to the radiator grille opening panel reinforcement (8A284).
Remove radiator grille.
Installation
Follow removal procedures in reverse order.
Tighten screws to 1-2 Nm (9-18 lb-in).
http://www.diesel-dave.com/vehic/manual/stj/images/n11189c.gif
1 N806851-S100 Nut
2 8326 Radiator Air Deflector
3 N805230-S55 *****
4 N623332-S100 Nut
5 N807260-S55 *****
6 17E940 (LH) Front Bumper Stone Deflector Filler
7 17E902 (RH) Front Bumper Stone Deflector Filler
8 N801603-S55 *****
9 17626 Front Valance Panel
10 8200 Radiator Grille
11 8A284 Radiator Grille Opening Panel Reinforcement
A — Tighten to 6-8 Nm
(53-71 Lb-In)
B — Tighten to 1-2 Nm
(9-18 Lb-In)
C — Tighten to 4-9 Nm
(35-80 Lb-In)
Post pics of it after it is intalled
danno
