Here are some;
Explorer Installation in an 83; "...The roof rack came from a '96 4-door Explorer, but was cut down one mounting *****. The runners are uncut. T-nuts are much more expensive than blind nuts, so I broke the tabs off. The screws are stainless. I hate shiny things, but none of them are visible when the rack is installed. Some of the nuts have to be spaced down or shortened because the roof is so thin. Although silicone helps hold the nuts while screws are being installed, the first camper I did this to had none and never leaked. Using the shortest screws available (~1/2") allows a stock '92-96 headliner to fit. cut the front of the tracks down by 1 ***** hole and installed 2 rear crossbars because they can both be (re)moved without tools. The original front bar is screwed in place. I also added more tie-downs. Outside dimensions (after cutting it down) are 43"Lx42"Wx3.5"H The support runners are 42"L. Although I'm not using these gaskets, I replaced the trim in them. It's more difficult than installing the windows in the shell..." Click Next to see more pics w/info
Source: by Steve at
http://api.viglink.com/api/click?format=go&jsonp=vglnk_146914128348411&key=6ed47b392b9edfe394b9e89b72717104&libId=iqwwr43i01000bgv000MAbc2jerk7&loc=http%3A%2F%2Fwww.fullsizebronco.com%2Fforum%2F16-anything-else%2F204770-roof-rack-ideas.html&v=1&out=http%3A%2F%2Fwww.supermotors.net%2Fregistry%2Fmedia%2F72073&ref=https%3A%2F%2Fwww.google.com%2F&title=roof%20rack%20ideas%20-%20Ford%20Bronco%20Forum&txt=http%3A%2F%2Fwww.supermotors.net%2Fregistry%2Fmedia%2F72073
http://www.hollanderparts.com/
A yard that uses Hollander Interchange can search other yards and have it shipped
Can select certain parts
Has Vehicle Pics! They show about 3 - 5 pics for some vehicles
No results in a quick search
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pics! They show about 4 - 5 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay.
Can NOT Select certain parts, search range is 80 to 96, select body
http://www.car-parts.com/
Has Some Vehicle Pics! They show about 4 - 8 pics per vehicle incl. interior/dash, back seat, front & rear and engine bay
Select
1980 - 1996 Ford Bronco (Full Size)
Roof Rack
Non-Interchange:
4 hits. From $44.00 to $45.00
http://www.picknpull.com
This is a Company name w/yard locations in various states
http://row52.com/Search
Has Vehicle Pics AND Want a Part? It's Easy...
1. You create a Parts Wanted Listing.
2. Parts Pullers respond with offers.
3. You pick the best one.
A Parts Puller gets the parts you need.
