95 Eddie Bauer small upgrades
Stipebronco
Florida
I am new to all this stuff and have a smaller budget. I drive a 1995 bronco Eddie Bauer and I am thinking about smaller upgrades/fixes. Have any suggestions?
Driving in the heat of the day in Florida she runs a little hot. On the highway the gauge reads on the letter L in normal. ( the temperature gauge uses the word normal not temperature )Also have some problems with late and hard shifts.
Have heard a lot about cold air intake and all but does that really work.
Read in an LMC ford truck magazine that says a certain header can boost by 10% mpg and 20% on hp is that true?
Any suggestions and pros/cons of what I mentioned?
Yo Stipebronco,
I guess you have the E4OD, if so, Consider a cooler, such as Cooler, B&M Installation in a 93
Source: by Kevin L @ http://web.archive.org/web/20070905192639
Pics are gone.. or
Cooler Installation (Hayden) in a 96
Source: by David C (Zak the Bronc, Big Green and ***** Dangling Dave @
http://www.supermotors.net/vehicles/registry/1493/25118
Have you flushed your cooling system in past year or 2?
If not then it may need a power flush.
Is the Transmission Control Switch (TCS) and Indicator Lamp (aka overdrive on/off switch and led) blinking while driving?
For shift issues, try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Some basics;
Do KOEO test First
KOEO
KOER
As for the headers, others can provide info on it.
ForPerformance Comparison Tests in a Centurion 460; miesk5 Note, Results are Comparable to Tests in other Ford Engines Source: by FOUR WHEELER Magazines Project M.P.G. . via
http://performanceunlimited.com/projectmpg
Rons beast
Hey Stipe,  welcome.
I live in Fl. too.  having the temp gauge at the "L" s a bit high.
I replaced my thermostat with a 180 instead of the 190....I had a 160 in but it took too long to heat up in the winter and my wife complained.
Be sure the rad and condenser are clear of bugs and debris.
I have not found headers that really improve the performance unless the engine is running high RPMs.
You can get a K&N filter for the air box, but keeping the standard filter clean and replacing often is just as good.
Stay away from the "cold air intake" kits that use a filter under the hood.  They actually cause more heated air to be induced than cold air.  I insulated the air horn to the grill and made an insulated box around my intake. ( it came from the previous owner with one of the "cold air intake " systems that was a disaster.)
My opinion : keep the stock exhaust, and intake and insulate the air box and intake tube. Give the engine a good tune and a good set of plugs if you haven't already.
Good Luck
kenrh
bonners ferry, id.
When new mine would would stumble, backfire at slow speeds on a hot day.
The intake  situated on the core support is a bad location, on a 90°.day teh temp. at that location was 165° at low speeds.
I installed a dryer vent hose on the bottom of air box, ran to the opening nest to the radiator, used a sheetmetal vent to hold it in.
Problem solved.
As Ron and kenrh advised,
Air Tube & Box Insulation pics in a 94 5.0; Ken used Reflectix Insulation, avail @ Lowes. etc. ST16025 - 16" x 25 feet. miesk5 Note; Ken installed the K&N® & removed the cold air intake tube that runs to the top of the radiator; but he could have installed the intake tube section later.
http://www.supermotors.net/clubs/superford/registry/9319/29460
Excerpts,
Utahstroke
