94 Horn and Cruise Control
raca65
Everything else works in this truck except these 2 items. This is a low mileage truck and a read somewhere that this is a common problem can someone explain a common easy fix? Thanks in advance. Sorry meant to say Horn and Cruise control...
The problem is most likely the ground contact in the steering wheel, it tends to wear out after several years due to the rubbing caused by steering.  In my truck it is a spring loaded brass contact, cost me $35.00 from a dealer who had to search all over the country for one.
Yo raca65,
Do you have a 94 Bronco or a 78?
I assume a 94.
R
raca65
Right now I have a 88 that I am parting and a 94 that I am keeping. I have had a 78,79,85,90. My favorite was the 78.
R
raca65
Seabronc does this require me pull the wheel and I wonder if the 88 would have the same part??
Utahstroke
