Engine cranks, won't start
cool79bronco
  1. I am having the same problem with mine. It cranks great but no fire. I will start with the brain box and see what happens. Thanks for the advice everyone. It's awesome to have so many ppl to help us beginners out.
C
cool79bronco
Ok I changed the ignition module and coil and still just cranks. Any other ideas? Thanks.
You need to do a little trouble shooting to determine if it is a fuel, spark or timing problem.  Some info from an 83 but the ignition should be pretty much the same.
C
cool79bronco
Turned out to be the cam gear was broken. So new cam, lifters and timing gear set and she runs like a beast. Thanks for the help.
