Parking brake levers Help!!!
96bluebeast
Looking for left and right parking brake levers for rear. Please Help!!!!!
96bluebeast
96bluebeast
Ok so got the parking brake back in works great in drive holds the bronco no problem but in reverse not holding is this normal for a bronco? If not ideas. I ran it in reverse to set the drums
It should hold a bit in reverse. Ford does not mention this at all in the 96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD
nor the 96 Bronco Owners Guide by Hiller Ford @
http://www.hillerford.com/resource_library/owner_manuals_pdf/1996_owner_manuals_ford/96bronco.pdf
EXCEPT,
"The parking brake is not designed to stop a
moving vehicle, but you can use the parking
brake to stop your vehicle in an emergency if
the normal brakes fail. However, since the
parking brake applies only the rear brakes, the
stopping distance will increase greatly and the
handling of your vehicle will be adversely
affected."
As long as it holds on a slope with engine off & the Bronco facing either uphill or down hill, its good.
The Owners Guide gives info on setting the parking brake.
96bluebeast
96bluebeast
My driveway is sloped and it won't hold uphill, I think check cable tension right
OK,
See the manual, parking brake section, it has a diagnosis section
Section 06-05: Brake System, Parking
