I have an issue where the engine will die at idle or driving like the key was turned off. It starts right back up. It is a 75 302. Manual trans.
I've replaced, coil, distributor cap, rotor, wires, fuel filter, rebuilt carburetor.
I tried replacing the ICM from AutoZone, and it gets worse. Won't start.
Sometimes I can drive 20-30 miles. No problems. Then drive 3 miles and it will die several times.
I read maybe the pickup module on the distributer, but it was on 90's bronco.
Any ideas?
Thanks Chuck
Any ideas?
Thanks Chuck
