Engine squeals
irishrednek
Ok I have already put this in my last post but since it is a different issue I thought I would start a new thread.
OK so after fixing the wiring issue and getting Ole Duty (my girls named her) up an running I seemed to have developed a squeal in the engine. I originally thought it might be a vacuum leak because I ended up replacing the tube on the egr valve that goes under the intake. All the vacuum lines came off the went back in place.
When the noise started I double and triple checked all the lines. The guys at work said that it could be the A/C compressor. I pulled the belt off started it up and still squeals. So the things I have found so far
Engine squeals after it warms up
If I push the gas pedal it goes away
If I put in cruise it goes away.
What else can I do to find this leak? Everything else seems to work fine just the annoying noise.
Use the old mechanic stethoscope method.  Get a short piece of hose, put one end of it to your ear and move the other end around to locate the squeak.  Watch out out for the fan blades.
