1994 5.8L cat outlet size
KYbronco3
What size is the outlet on the stock catalytic converter for a 1994 5.8?? If it's 2 1/2". Where can I find a 2 1/2 - 3" straight reducing adapter??
Rons beast
I believe it is 2 1/2" out of the convertor. O'Reillys and Advance auto show 3' to 2.5" reducers.  I have also found it sometimes easier to have my local muffler shop make me what I need, rather than spend hours chasing that elusive exhaust part.
Good Luck
Yo ky,
This info is by Walker who was OEM exhaust system supplier to Ford for most of the big Bronco and trucks...
I looked in epa converters catalog:
1994 - Ford Bronco
Engine - 5.8 Liter V8
Fitment Direct Fit
Inlet Count 2
Inlet Connection Type 2 Bolt Loose Flanges
Outlet Count 1
*** Outlet Diameter 1 2.250"
Outlet Diameter Designation Outside Diameter
Outlet Connection Type Pipe Connection
Body Material Stainless Steel
Body Shape Front Oval& Middle Round
Substrate Material Ceramic
Overall Length 69.500"
Oxygen sensor location Pre & Post Catalyst
http://www.walkerexhaust.com/catalog/epa-converters/e-catalog-lookup/16365
I then went to the exhaust catalog and looked up the muffler, tail pipe etc. And it shows SAME SIZE.
SEE IT AT
http://catalog.walkerexhaust.com/catalog/resultsDiagramDisplay.do?diagramNumber=13_02501&catalogCode=walkerexhaustasset&locale=en&loadStatus=ACTIVE
Fryman22
