Had a dream of a ´82 and now a nightmare of a ´94... Still lover her
ciakow
Hi all,
Big (6´7") Dutchy living in Colombia now (the country, not the ´American´ Columbia
Way back in 93 or 94 I had a ´82 Bronco where the previous owner replaced the engine with a spanking new 6,4l (or something) BigBlock.
Was in love with that matt black devil. Stripped of all luxury it took me everywhere and I did 115 Mph on the highway easily.
Over a year ago I bought a ´94 Bronco XLT 302 Automatic and it´s seen the mechanic about every week or other week.
Long story short: almost all sensors have been replaced, engine has been overhauled, automatic has been rebuilt all new, straightened, new pistons, valves, gaskets, 5x different spark plugs, 4x different cables, fuel pump, water pump, idle sensor, radiator, thermostat, distributor, and some cosmetics. (Think I´m forgetting a few things)
Last week (mid feb 2016) they told me my crankshaft damper was bad. Made a huge difference because, after setting the timing again, it runs smooth as silk.
But a problem that I have had since the beginning: The car is slow as.... anything.
Nobody seems to be able to help me and I´ve dropped so much money into the car that the bottom (of my money, not the car) is in sight...
Been strawling forum after forum and some good tips, some bad ones but to no avail!...
I´m here for that magic person that can lead me into the holy land of torque... (without changing the engine for now...)
Oh yeah: It did read 209.9 at the wheels and 473 lbs torque, which is spot on. Compression 170-175.
32" wheels, original differentials.
I´m lost...
(pics will follow)
Yo Dutchy,
Did the shop check for diagnostic trouble codes (DTCs)?
Try a Self Test for Diagnostic Trouble Codes (DTC)s by my pal, BroncoJoe19
http://broncozone.com/topic/14269-code-reader/?pid=74587&mode=threaded
Be sure A/C is off and transmission is in Park (automatic); or in Neutral for a Manual & release clutch.
Do KOEO test First
KOEO
KOER
This is by Ford from:
96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via
http://www.diesel-da...stj/stjleft.htm
Same as most earlier years especially 92-96, excepts for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 03-00: Engine, Service
DIAGNOSIS AND TESTING
Symptom Chart — Engine Diagnosis
http://www.diesel-dave.com/vehic/manual/stj/stj30006.htm
Insufficient Power
Malfunctioning hydraulic valve tappet.
REPLACE hydraulic valve tappet.
Damaged hydraulic valve tappet guide.
REPLACE hydraulic valve tappet guide.
Compression leakage at valve seat.
SERVICE or REPLACE valve, valve seat and/or cylinder head.
Seized valve stem.
REPLACE valve stem.
Weak or broken valve spring.
REPLACE valve spring.
Damaged cylinder head gasket.
REPLACE cylinder head gasket.
Cracked or distorted cylinder head.
REPLACE cylinder head.
Damaged, worn or sticking piston ring(s).
SERVICE or REPLACE piston ring(s).
Worn or damaged piston.
REPLACE piston.
Malfunctioning or damaged fuel system.
Malfunctioning or damaged ignition system.
REFER to Powertrain Control/Emissions Diagnosis Manual OBDI or OBDII.
Slipping transmission.
REFER to Section 07-01A, Section 07-01B or Section 07-01C depending on transmission.
Dragging brakes.
Incorrect tire size.
Damaged or plugged exhaust system.
REFER to Section 09-00.
Next is E4OD
Section 07-01A: Transmission, Automatic, E4OD
http://www.diesel-dave.com/vehic/manual/stj/stj71a24.htm#extract_1037
Power/Engine Performance — Poor Engine Performance
Refer to Routine No. 253/353.
253 — ELECTRICAL ROUTINE
Powertrain Control System
Perform torque converter operation test.
Electrical inputs/outputs, vehicle wiring harnesses, powertrain control module, other engine related items, torque converter clutch solenoid, throttle position sensor, transmission range (TR) sensor, transmission fluid temperature sensor
Run On-Board Diagnostics. THIS THE SELF TEST FOR DTCs
Refer to Powertrain Control/Emissions Diagnosis Manual for diagnosis. Perform Service Manual Pinpoint Tests B, C and D using Rotunda Transmission Tester 007-00085, Cable and Overlay 007-00107 and the Transmission Range (TR) Sensor Cable "B" (MLPS Manual Lever Position Sensor Tester Cable) 007-00086 or equivalent as outlined in this section. Service as required. Clear codes, road test and rerun On-Board Diagnostics.
353 — HYDRAULIC/MECHANICAL ROUTINE
Shift Linkage (Internal/External) or Cable
Damaged, misadjusted
Inspect for damage. Service as required. Verify linkage adjustment as outlined. After servicing linkage, verify that the transmission range (TR) sensor is properly adjusted. Refer to In-Vehicle Service in this section.
Shift Scheduling
Perform Shift Point Road Test procedure as outlined in this section.
Improper
Go to the appropriate diagnostic routines for shift concerns
No. 210-211.
Engagements
Improper gear selection
No. 215/315.
Converter Clutch Always Applied
Go to routine No. 341.
Converter One-Way Clutch
Damaged
Go to Torque Converter Checks in this section.
So, can you rule out any of the above?
Rons beast
Hey cia,  Welcome
That 94 will never be a roadburner with that engine.  It is simply too heavy.
You mentioned your 82..."strippedof all luxury" and it had a big block.  Well more engine and less weight is the only way to be fast.
There isn't any secret for that  302 in a heavy truck to make it fast.
Sorry, but hope you have fun anyway.
Fryman22
