GreenMachine
- Joined
- Jan 31, 2016
- Messages
- 7
- Reaction score
- 0
Hi all,
I have a 1995 Bronco 5.0L with a mysterious battery drain of about 200ma. I have used a clamp-on ammeter on the negative cable to the body as well as an inline ammeter between the terminal and post. I mostly use the clamp-on because it is easier but the values fluctuate between 170 - 300ma. The battery voltage was 12.33v two days ago. It is 12.22v today.
- Checked the alternator to see if diodes were leaking. It tested good. No change.
- Checked each fuse inside and under hood with a voltmeter to see millivolts. There were three possibilities and each fuse was pulled ( and yes, I closed the door to turn off the dome light). No change.
- Pulled each fuse, circuit breaker, flasher, diodes, and relays one at a time. No change.
- Pulled ALL fuses, circuit breaker, flasher, diodes, and relays inside and under hood. No change.
- Replaced ignition switch under steering column. No change.
- Replaced key cylinder for another issue. No change.
- Unplugged airbag control module under dash. No change.
- Unplugged PCM from engine compartment. No change.
- Removed starter relay from side wall (no ground means no circuit). No change.
- Removed alternator again. No change.
- Removed battery. NO DRAIN. haha Just kidding.
I am stumped! The dent is getting bigger from beating my head. What else could be leaking with the key off?
Thanks,
Tom
Thanks,
Tom
