HOOD STUCK SHUT!?!?
Bad1993
I had a water leak so I climbed on top of the hood to take the windshield trim off and I'm guessing my weight has the hood jammed shut I tryed to open it that same night because I noticed my corner marker light burned out and the release lever just makes a thud like the mechanism is working but not popping the hood up... Any suggestions will be great. Thank you
Bad1993
Old trucks play old tricks I geuss.... It fixed it self while in was driving down the smoothest road it popped up.. One more problem checked off my list.
Yo b,
Fyi,
96 Bronco-F-Series Workshop Manual (PARTIAL) by FORD via
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Same as most earlier years especially 92-96, excepts for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
Section 01-02: Body Panels, Front End
1996 F-150, F-250, F-350, F-Super Duty and Bronco Workshop Manual
ADJUSTMENTS
Hood Hinge
Open hood (16612).
On one side, place a rag between hood and cowl and loosen hinge-to-hood screws, then retighten snugly but not tight. Remove rag.
Close, but do not latch hood (secondary latch will latch, but not primary). Adjust until parting line between hood and cowl is even all the way across and the distance between the hood and the front fenders (16005) is even on both sides and front to back.
Raise hood and tighten hood hinge screws.
Close hood and make sure it latches properly. If necessary, adjust hood latch (16700...
http://www.diesel-dave.com/vehic/manual/stj/stj12023.htm
And http://www.diesel-dave.com/vehic/manual/stj/stj12008.htm
http://www.diesel-dave.com/vehic/manual/stj/stj12007.htm#hlri120
