Getting fuel and spark, no start.
Kenny boy
I have a 1986 bronco with a 5.0 302. The problem is that Im getting fuel and spark, but when I try to start the vehicle it wont run. It will only start if the engine is starved for fuel. Once it starts if it is given fuel again it will continue to run but at a ridiculous rpm. (Around 2000-2500) I really need help with this one. I've changed the fuel pressure regulator and cleaned all of the injectors, along with the entire fuel system.
The length of time that the injectors fire is controlled by the computer.  Either it is getting a bad input or it may be bad.   Have you checked for codes?
Fryman22
