Bwhitewr45
- Joined
- Jan 28, 2016
- Messages
- 1
- Reaction score
- 0
I have an '89 bronco and when I bought it, there was a battery drain. I disconnected the negative terminal, used a multimeter and with the truck off, something was drawing about 2.5 amps. I started pulling fuses and found that it was fuse slot 4 (exterior lamps, instrument illumination, glove box lamp, and roof map lamps). When the truck is off I can't visibly see any of these lights on so I have no clue how to fix this problem. Any help would be appreciated!
