Widow track problem
strong918
Has anyone ever ran into problems where you roll you window down and it falls off track if so how did you fix it
I would guess that the track is either loose, bent or out of alignment.  You need to take the door panel off and observe where the window is on the track when it falls off.
strong918
strong918
alright thank you needs to be fixed so I can install the power window kit from LMC
