Hey Jacobs, Welcome.
Here is an easy test.:
First check that there is power at the + terminal of the coil with the key in the "on" position.
If not , you need to find the break in the ignition coil power wire.
If there is power there, do the following:
Connect a test light between the + and - terminals of the coil.
Crank the engine. Look for the light to flash.
If there is flashing there is a breakdown in the wire from the coil to the dist. cap.
No flashing means there is no "fire" signal to the coil. ( The most common cause is the ign. control module, or the pick up coil in the dist.)
Often these "no flash" conditions are the module.
Please fill in your signature with the info on your bronco...engine size, tranny, and any mods. It's helpful when trying to diagnose problems.
Good Luck
