Parking brake cable routing
KYbronco3
Hey guys,
Think I may have either a routing or adjustment issue on my 94 Eddie Bauer 5.8. This started with a scraping noise from the passenger side drum....I am replacing everything except the wheel cylinders in the drums.....when I pulled the passenger side drum off the auto adjuster spring and mechanism that the spring connects to was laying in the drum.....my current issue is the parking brake cable is very tight in the drum, I ensured the brake was off, but had a very hard time getting the lever back on to the cable. Does anyone have the correct cable routing for the parking brake cable????
yo KY,
Removal & Installation; Adjustment & Cables & Diagrams
Source: by Ford via Steve
http://www.supermotors.net/registry/media/283545
Cable Sheath Removal; "...This is the easiest way to remove e-brake cable sheaths: slide a 1/2" box-end wrench over the end of the cable & use it to release all 3 clips at once..."
Also see
96 Bronco-F-Series Workshop Manual (PARTIAL)
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Same as most earlier years especially 92-96, excepts for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
Group 06: BRAKE SYSTEM
http://www.diesel-dave.com/vehic/manual/stj/stjs650l.htm
"...Inspect the parking brake control (2780) and look for loose mounting bolts, damaged or missing parts. Operate the parking brake and check for binding or seized components. Raise and support the vehicle and remove any debris that may interfere with parking brake operation. Check the condition of the parking brake cables. Look for abrasion or cables rubbing on body or frame parts. Repair, replace or reroute as necessary. Remove the brake drums (1126) and have an assistant operate the parking brake just enough to observe operation. Look for damaged or missing parts. Lubricate parking brake parts with Disc Brake Caliper Slide Grease D7AZ-19590-A or equivalent meeting Ford specification ESA-M1C172-A..."
Source: by Ford
DonLawson84
If you want when i get home i can snap some pics and email them of my 94's cable routing
