Hey just bought my first bronco but having some trouble getting it to start.
first I took the starter off and had it tested, it was fine so I bought a relay solenoid put it on nothing.(I can jump it and it will crank right up.)
I cleaned all the electrical connections I could get to, still nothing
I was wondering if any of you have come across this problem before? is there any way it could be a relay in the fuse panel
when I turn the key on everything comes on fine as normal but once I go to crank it up everything shuts off. once I stop trying to crank it everything (radio,lights,instruments) comes back on.
Thanks for any input I'm lost!
