aftermarket stereo wiring harness 1973 Bronco
bigbeardbiii
Alabama
I searched but couldn't find a thread for this topic. I'm in need of any & all info. I can get on a stereo wiring harness that will connect an aftermarket stereo. All I could find only went back to 1982 (Scorche).
If I understand your post..., EB's never came with a stereo.
They came with a simple AM/FM radio.
If you want a stereo set-up.., you'll have to build a small wiring group with a fuse.
Basically, all you need is a pos. a neg. & in some cases a light wire.
All the other wiring is from the stereo to the speakers.
bigbeardbiii
bigbeardbiii
Alabama
Yes, I'm use to calling ALL in car radio's "stereo's", regardless of if only am, am/fm,cd, etc... Mine did come with an am/fm. Thanks for the info. Where do the wires you mentioned connect on the vehicle end?
Which one RU hook'n up.., your AM/FM or something else.?  I assume the aftermarket.
Your fuse box has a fuse for "radio"
OR.., you can install a fuse-block under the hood for a radio and any other elect. add-ons
you may choose to install in the future.
None of this is hard but not really explainable on a keyboard.
However, it has to be done right. (shorts &/or fire are not a fun thing.)
You should go to the libuary & read up on some basic wiring hook-ups.
Most aft. market radios come with instructions & a simple schematic.
bigbeardbiii
bigbeardbiii
Alabama
Thanks Bob & Carid. I'll check into the Metra & Am. Int. wiring harnesses.
Lana Kane
