'83 bronco-gas mileage and restoring
'83Bronco323
Okay so i got what i think is a really good deal on an 83 bronco with the v8 302 5.0 in it but it is missing the ac unit and the smog control and has a whole in the floor pan and wasnt running but i changed out the valve cover gaskets, put in new plugs and wires, did a complete oil change on it and found out the it had gas in the oil and added a new pcv valve and found out that it has an exaust leak an evap leak and the heater core was done for. What sites does everyone reccommend for parts if you have a budget to restore it and get it running over like 10 years haha. I also have to get new headlights, a grill and a new fender and a new carb.
Hi '83.., welcome..!!
Ouch..!!   I hope ya got it "free" ..... >:D< <'>
I think you'll need a factory manual or, at least a Haynes or Chilton manual.
-OR- spend some time in your local libuary.
Wrecking yards &/or a donor veh. may be in order.
Enjoy the project.
Our SPONSOR, Jeff's Bronco Graveyard has a nice parts inventory! For the items I bought, all came in on-time and well built such as radiator core support, etc.
http://broncograveyard.com
Heater Core No A/C, 1980-86
New
No A/C $27.00
1980-86 Ford Bronco
Heater Core With A/C, 1980-86
New
With A/C
1980-86 Ford Bronco
1980-86 Ford F100, F150, F250, F350
$28.00
Compare $ to Ford's Parts Site; http://www.fordparts.com/Commerce/CatalogResults.aspx?y=1983&m=Ford&mo=Bronco#Search
HVAC Heater Core w/ Integral A/C, Heater Only, or Hi/Low Vent System
$155.18
Also check Library; mine has All Data on-line for free but in-library use only; All Data uses the Ford docs
Chilton; many local library's offer free on-line access for their members;
just log-in w/your library Card # and password; incl. all Broncos, & many MAKES! 1951 to Current;
some years (85-96, I believe) include: FULL Technical Service Bulletins and Recalls, Labor Hours per repair (plug in appl info); Wiring Diagrams, Vacuum Diagrams (in DRIVEABILITY AND EMISSIONS CONTROLS Section), Specifications (torques, etc.) & Maintenance Intervals
As Bully advised, the Haynes Manual is an economical resource
Look for one at local used book store; or on ebay, etc.
Get HAYNES red cover edition Ford PICK-UPS & BRONCO 1980-1996
AutoZone has tech info similar to Chilton
http://www.autozone.com/
Register, Enter vehicle info and go to VEHICLE REPAIR GUIDE
Here are the sections;
Engine Electrical
Driveability & Emissions Controls
Brakes
Suspension & Steering
Chassis Electrical
Routine Maintenance
Engine & Engine Overhaul
Body & Trim
Drive Train
Fuel System
Specifications; I list a few as examples
A/C System Refrigerant Capacity (this is what they provide (SEE NOTE Refrigerant: R-12. Capacity: 54 oz. (1.5 kg.))
Battery Group Size
Brake Drum Maximum Machining
Brake Fluid Type
Brake Rotor Minimal Machining
Clutch Installation Bulletins
Clutch Master Cylinder Fluid Type
Cooling System Mix
Differential Fluid Capacity ( 1983 Ford Truck Bronco 5.0L 2BL 8cyl)
Quarts1.8 quarts (1.7 liters).Location: F.Unit: Dana 44
Differential Fluid Type
Engine Oil Type/Weight/Capacity
Exhaust Manifold Bolt Torque
Firing Order
Fuel System Pressure
Head Bolt Torque
Ignition Timing
Intake Bolt Torque
Interference Engine
Lug Nut Tightening Torque
Main Bearing Cap Torque
Power Steering Return Hose Length
Rod Bearing Cap Torque
Spark Plug Gap
Spark Plug Tightening Torque
Transfer Case Fluid Capacity
Transfer Case Fluid Type
Transmission Fluid Type/Capacity
Valve Cover Bolt Torque
I get my Ford parts via AMAZON; they are VG at delvy and esp pricing; I bought a $150.00 DPFE Sensor (not incl. sales tax) for $50.00 with free shipping and no state sales tax; same for the IAC sensor.
http://www.rockauto.com/
Some items that may interest you;
1983 BRONCO 5.0L 302cid V8 Heat & Air Conditioning A/C Evaporator Core Repair Kit
FOUR SEASONS 16152 Evap Core Rep Kit
Repair Kit; w/o Spring Lock; w/ Tube (Blue)
FOUR SEASONS 16155 Evap Core Rep Kit; 3/4-16 threads
Evaporator Core Repair Kit for Ford FOTCC System with Springlock Coupling.png
Repair Kit; w/ Spring Lock; w/o Tube
ETC.
ATP 101040 {#F3TZ9431N, M327139} Left Exhaust Manifold; Includes Necessary Hardware
Left; For Use Without Heat Riser; w/o Oxygen sensor hole; Includes (1) manifold gasket, (2) studs, (2) nuts, (2) washers $69.89
DORMAN 674155 {#E3TZ9431A, E5TZ9431B} Hardware: 2 Studs, 4 Nuts
Left; w/Exhaust Control Valve $66.79
ATP 101025 {#E3TZ9431A, M327124} Left Exhaust Manifold; Includes Necessary Hardware
Left; For Use With Heat Riser; Includes (1) manifold gasket, (2) studs, (2) nuts, (2) washers $75.79
ETC.
Dennis Carpenter - 66 - 89 Bronco/Ford truck & car parts & accessories w/parts break-out diagrams & Ford part numbers; Click Get Catalogs http://dennis-carpenter.com/default.aspx
http://www.lmctruck.com
LMC TRUCK® (Long Motor Corporation) - Bronco/Ford truck parts & accessories & 66-77 & 80-96 Bronco weather stripping & camper top side window sliders (Manufactured by C.R. Laurence); Click Free Catalog
See exhaust manifolds and gaskets http://www.lmctruck.com/icatalog/fd/full.aspx?Page=133
and evaps, ETC.
Metro Moulded Parts - rubber restoration parts & Bronco/Ford truck weather stripping; Click Free Catalog
http://metrommp.com/
Mill Supply - Bronco/Ford truck body panels, interior door panels, weatherstrip, mirrors, headlights, tail lights, side marker; Click Order a CATALOG their body panel site is http://www.rustrepair.com
National Parts Depot - Bronco/Ford truck parts & accessories; Order your Printed NPD catalog
http://npdlink.com/store/
Jgrden
Crosby, Texas
Sounds like you and I b ought from the same person. My '85 needs tons of "weekend mechanical" work. So far: dimmer switch, hood release, brake light switch, repaid console cover, evacuated the r12 to prepare for the 13a, repair under the hood light, cleaned, vacuumed, aligned, dried.out.
Need:
  1. Rust repair
  2. Finish retrofit of A/C
  3. Find center bezel and radio
  4. New seats
  5. Insulation,
  6. Interior door panels
  7. Headliner
  8. Speedo cable for cruise control
  9. Paint and then drive
It runs GREAT! and has a rebuilt motor. The transmission shifts perfectly. Keep us posted on your progress. I think I am tiring others out with my weird ideas and calls for help. Supreme Commander has been very helpful and patient.
Carchico77
