To Confirm Bob's info;
See 96 Bronco-F-Series Workshop Manual (PARTIAL)
Same as most earlier years especially 92-96, excepts for OBD II in 96, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96); Spark Plug Wire Routing & Firing Order (The firing order for 1987-1993 5.0Ls is 1-5-4-2-6-3-7-8. The firing order for 1994- 96 5.0Ls & all 5.8Ls is 1-3-7-2-6-5-4-8.);
2-piece Spindle Rolling Diaphragm Seal (RDS) used on 5/95 to 96 Broncos & F Series 1/2-ton 4WD
and a few other items that I still need to research
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 03-03: Engine Cooling
CLEANING AND INSPECTION
http://www.diesel-dave.com/vehic/manual/stj/stj33031.htm
EXCERPTS;
Coolant Condition Check
A reddish brown color indicates rust in the cooling system. Advise the customer that the best course would be to flush the cooling system and refill with the correct 50/50 coolant mixture. Ford Premium Cooling System Fluid, E2FZ-19549-AA or equivalent meeting Ford specification (ESE-M97B44-A and ESE-M97B43-A) contains corrosion inhibitors. In addition, add 1.4 liters (1.5 qts.) of Heavy-Duty Cooling System Additive FW-15 or equivalent meeting Ford specification ESN-M99B169-A.
An iridescent sheen on the top of the coolant indicates a small amount of oil entering the coolant. This is common in high-mileage vehicles.
To remove rust, sludge and other foreign material from the cooling system, use Ford Premium Cooling System Flush F1AZ-19A503-A or equivalent meeting Ford specification ESR-M14P7-A. Flush system using Rotunda Cooling System Flusher 106-00010 Flush Kit Hardware Package 106-R0011, and Drain Kit 106-R0015 or equivalent. Removal of such material restores cooling efficiency and avoids overheating.
Always remove the water thermostat (8575) prior to pressure flushing. A pulsating or reversed direction of flushing water flow will loosen sediment more quickly than a steady flow in the normal direction of coolant flow. In severe cases where cleaning solvents will not properly clean the cooling system for efficient operation, use the pressure flushing method. Various types of flushing equipment are available.
Heater Core Back-Flushing
http://www.diesel-dave.com/vehic/manual/stj/stj33034.htm#extract_601
