73 roll bar/cage and bikini top
jbahorns11
I want to have a roll/cage bar installed with a bikini top. I may try to do it myself, but in all likelihood, I'll take it to someone to have it done. I want to make sure that I can put my top back over the bar.
Can someone tell me what type of roll bar/cage and or bikini top I need to use and any pictures would be very helpful should I try to do it myself?
Second question...any suggestions who in the Houston area could install these for me?
Thank you in advance,
jba
Hi JBA..., welcome..!
There's roll bars & then there's "Roll Bars"
Folks who get out there in the rough, & have situations where they could "roll over" ..?
They have "Roll Bars" ----- Meaning they're attached thru the floorboards & attach to the veh. FRAME.
Your truck is soooo.., cherry.., I doubt you'll ever get in a roll-over situation.  (I don't either)
Your needs would be the roll bars that attach to the floorboard. Yes, they would provide protection
in a roll-over but there would be floorboard damage.
These are EASY to mount with drilling & bolting.
A roll bar sits behind the seats.
A roll cage has bars forward & follows the shape of the windshield.., & has support bars runn'n down
on either side of the dash to the floor.
Then there's family set-ups that go all the way to the tailgate.
They ALL allow the hard or soft tops to be installed.
The Bikini fits them all & simple to install.
     You should go to  www.wildhorses4x4.com    &   www.tomsbroncoparts.com
They have pics of ea. setup.
The floor mounts are easy to install.., the frame mount req. a bit more work, including welding
in some cases.
LET US KNOW what you do & the results..!!! >:D< <'>
J
jbahorns11
Bully Bob,
Thanks for the great information.
One more question...See the attached pic showing my wiper motor assembly well above the profile of other Bronco's. What do I do about that?
Thanks,
jba
The rag top &/or bikini top come with a wiper motor "lowering bracket".
It too is easy to install.
They come with a sheet metal riser that bolts to the top of the W/S that allows clearance.
MarkBright'67
S.Pellegrino - Italy
Hi JBA ,..welcome ! . That's just an "option" i found..about ur issue :   cdn.wildhorses4x4.com/downloads/windshield.pdf   .  Your Bronco is really nice... :)>-
bigbeardbiii
Alabama
I just installed a roll "Bar" & went to Summitt's website after reading about the different bikini top brands and went with a Bestop with the metal riser addition in order to keep my wiper motor where it is from the factory. It came with directions & cut outs for how & where to cut your wiper motor cover a little more than an inch on both top *** edges & it work awesome. So, now I have a roll "Bar" with a bikini top that my hard top will fit over all while being able to keep my wiper motor at factory height & still being able to attach the cover so, I can have my sun visors!  If memory serves a factory roll bar's 41.5" tall (but someone with one can be more precise) which still allows not only for the hard top but also a inside top parchment cover too! I'll try to get a few pics & post them soon!
Chapin1736
