What is this?
Jgrden
Crosby, Texas
What is this? It is attached to my hood on the left side. There are two wires running to it. 1985 Ford Bronco XLT.
Happy Fourth. Let's celebrate!  Cheers
yo J,
As RON advised!
be careful of assy since it prob contains mercury
Under-Hood, Mercury Removal Guide, Bronco, Ford, 70-95, etc.
Auto Mercury Switch Removal
from Hoods and Trunks
Source: by wa.gov/pubs
http://web.archive.org/web/20120904054437/https://fortress.wa.gov/ecy/publications/publications/0504024.pdf
Notice that they left out our Broncos in the Listing.. but incl BII & F-Series Truck (F 150-550) 1974-2000
This light was used on ~'80~90 Ford trucks and some Jeep Cherokees (with a different connector). It reaches ~25' and has a magnetic base. There should be a clear dome over the #90 bulb, but the retainers break easily and the bulb is often replaced with an oversize one #1004, which melts the dome.
TSB 01-19-04 Revised Mechanical Hood Lamp Switch Replaces Mercury Switch
Publication Date: SEPTEMBER 18, 2001
FORD: 1990-95 ******
1990-2000 CROWN VICTORIA
1991 TAURUS
1992-95 E SERIES
1994 F-150, F-250, F-350
2000-2001 F-150, SUPER DUTY F SERIES
2001 EXCURSION
LINCOLN: 1888-89 MARK VII
2000-2001 TOWN CAR
2002 BLACKWOOD
MERCURY: 1990-95 GRAND MARQUIS, TRACER
1993-98 VILLAGER
ISSUE: This article is to provide information on replacement hood lamp switches. The 14 degree Mercury style hood switches will no longer be available. Replacement 14 degree Mechanical switches will be available as a service replacement.
ACTION: For vehicles requiring hood lamp switch replacement, replace the 14 degree Mercury switch with new 14 degree Mechanical switch. Replace hood lamp switch per the appropriate model year Workshop Manual as needed.
~25' of self-retracting cord (twists, knots, kinks, & dirt inside the case interfere), a tilt switch (which can keep the light on if the truck is parked on a steep incline), a magnet on the side of the bulb holder (for positioning the bulb on the steel body), and a globe to protect the bulb (but the bulbholder tabs break off, and the more-common oversize bulb melts the globe).
Old Service Part Number - New Service Part Number
F3XY-15702-A - - - - - - - - - - YW1Z-15702-BA
E8LY-15702-A - - - - - - - - - - YW1Z-15702-BA
PART NUMBER PART NAME
YW1Z-15702-BA 14 degree Mechanical Hood Lamp Switch
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: INFORMATION ONLY
OASIS CODES: 201000, 201200
J
Jgrden
Crosby, Texas
Sheesh, what will they think of next?? Guess I'd better take the unit off and give it a look-see. I tried to put the loose part back into the receiver but it falls  out. Retainer clips, as you mentioned, might be worn. Replacing the mercury buld should not be an issue, if it still exists.
My apologize for the messy looking hood and area but it is going to be brought back to new condition as we progress. Allot has to do with your sage advice. What a hoot. I love my Bronco.
J
Jgrden
Crosby, Texas
The unit is off and apart. Wires need replacing, no big deal. The little mercury switch was still in its holder but the spring contact broke off during my cleaning efforts. Everything I have read ssays to convert it to mechanical switch. There are two part numbers so it will be necessary to enter into a dialog with the parts personnel to see which one is correct. One part number is: TSB 01-19-04  and the other is: YW1Z-15702-BA. The buld was missing and it's part number should be 13466. The globe, which I assume will be hard to find, is 15703. It is apart on my workbench pending research and parts find. Anyone who has any advice please feel free. I am listening.
J
Jgrden
Crosby, Texas
Ford no longer carries these parts due to the age of my rig. Now going to Vintage auto parts.
Rons beast
Hey J,
I would put a simple switch somewhere under the hood or on the light holder. I wouldn't worry about the globe....that is unless you are restoring the truck and want everything as it came from the factory.
BTW how goes the R134 conversion?
yo J,
YW1Z-15702-BA
https://www.partsvoice.com/partsearch
shows multiple sources incl Green Sales Company
Availability: 4 found at 1 seller
Variations: YW1Z15702BA, YW1Z*15702*BA
Green Sales Company
(513) 294-8385
Tell them you found it on RearCounter.com
Recently Updated
Part Number: YW1Z15702BA Seller: Green Sales Company - View Profile
Description: Phone: Show Phone Number
Price: Request Pricing Email: Send Seller Email Inquiry
Quantity: 4 Location: Cincinnati, Ohio Map & Directions
http://www.rearcounter.com/YW1Z-15702-BA-parts158309.html
NEW OEM ENGINE COMPARTMENT LAMP 2000-2014 FORD LINCOLN VEHICLES #YW1Z-15702-BA
Fits multiple vehicles, see item description
C $40.80
Buy It Now
Free shipping
2d 3h left (Sunday, 16:09)
http://www.ebay.ca/sch/sis.html?_nkw=FORD%20OEM%20ENGINE%20COMPARTMENT%20LAMP%20ASY%201U5Z%2015702%20AA
$26.75
http://www.oemfordpart.com/ford/crown-victoria/yw1z15702ba/2000-year/lx-trim/4-6l-v8-gas-engine/body-cat/hood-and-components-****/?part_name=under-hood-lamp
I'll try to look for other parts later.
J
Jgrden
Crosby, Texas
WOW! These sites need to be Bookmarked. Thank you. The light has been refurbished and reinstalled sans bulb and globe and the new switch. I by passed the little Mercury switch. In fact, if there were a bulb in it it would be lit since no cut off switch has been installed yet. They make some door switches for a buck-forty five that look promising.
Thank you for your help.
yo J,
YW!
more parts sources/info on availability;
http://www.hollanderparts.com/
Select All Parts
year, etc, then FORD TRUCK
Has Vehicle Pics
Hollander Interchange System
"What is the Hollander Interchange?
The Hollander Interchange is a numbering system that indexes which parts are interchangeable among vehicles. For example, the timing cover for a 1976 GMC Truck also fits a 1969 Corvette. For more than seventy five years, automotive professionals have trusted the Hollander Interchange to help them save time and money locating parts.
What models are covered in the books?
Hollander Interchange Manuals cover most foreign and domestic cars and light trucks from the 1920s to the present. For a complete list of year ranges, click here.
What types of parts are covered?
The manuals cover more than 150 mechanical and body parts and assemblies."
http://hollanderinterchange.net/resources.php
or
http://www.copartfinder.com/finder/searchMake.do
Has Vehicle Pic!
http://car-part.com/
http://www.picknpull.com
This is a Company name w/yard locations in various states
Also for obsolete parts by Ford Part Number long version
http://www.partsvoice.com/
http://www.greensalescompany.com
__________________
Fryman22
