81 bronco custom exhaust
jbburn
Hi everyone. First off wanted to say hi and thatbi am new to the forums, just bought an 81 bronco custom 4x4 with a 302 and it has a manual trans. The question I have is the bronco has no exhaust manifolds or exhaust under it. I have found alot of places that sell a set of headers and exhaust but they all say for auto. Any ideas on places and full kits?
yo jb,
WELCOME!
81 w/MAC 1 5/8 direct replacement Equal Length Short Headers, dual 40 series flowmasters with 2 1/2" pipe in a 302 w/PICS
Source: by Matt K (81Bronk36, 1BadBronco) at http://www.superford.org/registry/vehicles/detail.php?id=1967&s=13295
Our Sponsor has headers and parts, etc,
see http://shop.broncograveyard.com/EXHAUST/departments/551/
Appears MACs has dropped the 81 HeAders; BUT CLL THEM;
http://www.macsautoparts.com/early_ford_bronco/exhaust.html
Other typical sources;
Summit Racing Equipment - Free Shipping on Orders Over $99
http://www.summitracing.com/search/year/1981/make/ford/model/bronco/part-type/exhaust-systems?SortBy=Default&SortOrder=Ascending
Dynomax Performance 89016 - Dynomax Header-Back Dual Exhaust Kits
Exhaust System, Dual Kit, Header-Back, Steel, Aluminized, Ford, Pickup, SUV, Kit
(2)
Part Number: WLK-89016 More Detail...
Estimated Ship Date: 6/29/2015 (if ordered today)
$146.97
Jegs High Performance
http://www.jegs.com/webapp/wcs/stores/servlet/MkMdlYrSearchCmd?searchType=MkMdlYrSearch&Nty=0&catalogId=10002&Ne=1%2b2%2b3%2b13%2b1147708%2b1147708&itemPerPage=60&langId=-1&MODEL=1593470&storeId=10001&YEAR=1592451&MAKE=1593469&N=1593470+4294966653
Dynomax 89016
Header Dual Kit•1980-95 Ford PU, 2WD and 4WD 1/2, 3/4 and 1-Ton
•1980-95 Bronco (Full-Size)
•Fits: Small Block 302 and 351-400M
•Runs down right-hand side between frame and drive-shaft
Header Dual Kits for Trucks
Item# 289-89016
Only $149.99
FREE SHIPPING
HEADERS;
32 Proucts @ http://www.jegs.com/webapp/wcs/stores/servlet/MkMdlYrSearchCmd?searchType=MkMdlYrSearch&Nty=0&catalogId=10002&Ne=1%2b2%2b3%2b13%2b1147708%2b1147708&itemPerPage=60&langId=-1&MODEL=1593470&storeId=10001&YEAR=1592451&MAKE=1593469&N=1593470+4294966649
carid; 163 Products; HERE ARE SOME SAMPLES:
http://www.carid.com/1981-ford-bronco-exhaust-systems/
Flowmaster®
Scavenger Series Elite Shorty Header
(0 reviews)
Ford Bronco 289 / 302 CID 1981, Scavenger Series Elite Shorty Header by Flowmaster®. Replace your restrictive factory exhaust manifolds with these stainless steel headers and let your engine breath! Their long tube design will...
Flowmaster®
220 Series Stainless Steel Oval Catalytic Converter
View Gallery
(0 reviews)
Ford Bronco 1981, 220 Series Stainless Steel Oval Catalytic Converter by Flowmaster®, 2.25" Inlet / 2.25" Outlet. 14" Length. 6.13" Width. Includes Heat Shield, Air Tube, 4 Bolt Flanges. Without Hangers. The new Flowmaster...
MagnaFlow®
Direct Fit Federal Catalytic Converter
View Gallery
(0 reviews)
Ford Bronco 1981, Direct Fit Federal Catalytic Converter by MagnaFlow®. 3" Inlet / 3" Outlet Diameter. 30" Wide. If your car needs replacement, install one that will get you through the smog check and give you more horsepower. This...
Eastern®
Direct Fit Catalytic Converter
View Gallery
(0 reviews)
Ford Bronco 1981, Direct Fit Undercar Catalytic Converter by Eastern Catalytic®. 38" Overall Length. Standard. 2.5" ID. 2.25" OD. Number of Clamps: Three Clamps. If you need to replace your failed or damaged catalytic converter,...
•Direct OEM replacement
Spectre Performance®
Exhaust Header Gaskets
View Gallery
(0 reviews)
Ford Bronco 1981, Exhaust Header Gaskets by Spectre Performance®. Rooted in racing, Spectre Performance designs and builds every product with the same goal in mind - the best performance in the market proven on the racetrack! All...
•High-tech engine parts for the most power and best performance
•The finest exterior and interior parts
Flowmaster® - Scavenger Series Race Collector Muffler
(0 reviews)
Universal Scavenger Series Race Collector Muffler by Flowmaster®. These Delta Force Mufflers are designed to attach directly to the exhaust header primary tubes, replacing the collector in sprint and drag racing applications. They...
$274.15
$219.32
# 898468
Flowmaster® - 40 Series Delta Flow™ Muffler
(1 reviews)
Universal 40 Series Delta Flow™ Muffler by Flowmaster®, AGGRESSIVE SOUND, 4" Thick x 9.75" Wide x 13" Case Length x 19" Overall Length. The 2-chamber design of this muffler, incorporating the patented Flowmaster Delta Flow...
$108.85
from $87.08
# 897054
Flowmaster® - 40 Series Original Muffler
Universal 40 Series Original Muffler, AGGRESSIVE SOUND, 4" Thick x 9.75" Wide x 13" Case Length x 19" Overall Length. This is the muffler that launched the success of Flowmaster. It is an aggressive sounding...
$108.85
$87.08
# 897079
Flowmaster® - 50 Series Delta Flow™ Slimline Muffler
Universal 50 Series Delta Flow™ Slimline Muffler by Flowmaster®, MODERATE SOUND. The 50 Series Delta Flow Slimline mufflers are designed for passenger cars. The sound characteristics are moderate exterior sound level and minimal...
$168.74
from $134.99
# 897156
Flowmaster® - 60 Series Delta Flow™ Muffler
(0 reviews)
Universal 60 Series Delta Flow™ Aluminized Steel Muffler by Flowmaster®, MILD SOUND, 2.25" Center Inlet / 2.25" Center Outlet, 5" Thick x 10" Wide x 13" Case Length x 19" Overall Length. The 60 Series increases horsepower and...
$163.98
$131.18
# 897052
Flowmaster® - 70 Series Delta Flow™ Big Block Muffler
(0 reviews)
Universal 70 Series Delta Flow™ Big Block Muffler by Flowmaster®, MILD SOUND, 5" Thick x 10" Wide x 22" Case Length x 28" Overall Length. The 70 Series Big Block II Muffler uses a longer case for increased volume and added...
$190.19
$152.15
# 897109
Flowmaster®
Pro Series™ Laminar Flow Muffler
View Gallery
(0 reviews)
Universal Pro Series™ Laminar Flow Muffler by Flowmaster®, MODERATE SOUND. PRO Laminar Flow mufflers have a patented core design that is characterized by efficient exhaust scavenging and minimized drone. They produce a rich, deep...
Borla®
XR-1™ Multicore Stainless Steel Race Muffler
(1 reviews)
Universal XR-1™ Multicore Stainless Steel Race Muffler by Borla®. The Borla XR-1 Multi-Core Muffler was developed on the race track to quiet the most severe engine noise without restricting power. They work so well that they're...
$306.24
from $244.99
# 959705
Borla® - Heavy Duty Stainless Steel Round Muffler
(1 reviews)
Universal Heavy Duty Stainless Steel Round Muffler by Borla®, 3" Center Inlet / 3" Center Outlet. Get increased performance and the aggressive sound of power with this Heavy Duty Stainless Steel Round Muffler. This muffler includes...
$262.49
$209.99
# 25728296
Universal CFT Superflow™ Oval Muffler by Gibson®. Get optimum usable power and a deep powerful sound with a Gibson CFT Superflow Muffler. The CFT Superflow has one of the lowest restriction ratings of any muffler on the market,...
$107.49
from $85.99
# 2060024
Gibson® - SFT Superflow™ Round Muffler
(1 reviews)
Universal SFT Superflow™ Round Muffler by Gibson®. Get increased exhaust flow for more power and great sound with a Gibson SFT Superflow Muffler. The SFT Superflow has one of the lowest restriction ratings of any muffler on the...
$117.23
from $93.78
# 2060137
Gibson® - Race Muffler
(0 reviews)
Universal Race Muffler by Gibson®. Inspite of the large host of engineers and technicians, Gibson Performance has not lost its commitment to building cost-effective exhaust systems that deliver more performance for less spendings....
Weapon-R®
Black Muffler
(0 reviews)
Universal Black Muffler by Weapon-R®. This muffler is a part of Weapon-R’s Inter-Lock Universal Muffler System. This system allows the length and style of the Exhaust Tip to be changed.
Universal Aluminized Steel S-Bend Pipes by Flowmaster®, 6 Pieces. The mandrel formed S-bend pipes are approximately 36” long and simplify the routing and fabrication of custom exhaust systems. They are sold in packs with 6 pipes...
$163.98
from $131.18
# 469122
Flowmaster® - Stainless Steel Mandrel-Bend Pipe
(0 reviews)
Universal Stainless Steel Mandrel-Bend Pipe by Flowmaster®. It is essential that the diameter of an exhaust tube is kept constant through bends, to avoid obstructions to the gas flow. Fitting Flowmaster Mandrel Bends for transition...
$52.40
from $41.92
# 4135393
Flowmaster®
U-Fit Dual Pipe Kit
View Gallery
(1 reviews)
Universal U-Fit Dual Pipe Kit by Flowmaster®, 16 Pieces. These kits come complete with all the pipes you need to build a custom dual exhaust system in 2.25", 2.50" or 3.00" pipe diameters. They include the front adapter pipes,...
$341.05
from $272.84
# 469100
Flowmaster® - Tailpipe Kit
(0 reviews)
Universal Tailpipe Kit by Flowmaster®, 4 Pieces. Flowmaster’s Universal Tailpipe Kits fit 90% of all Trucks, Vans and SUVs. They incorporate 12’ of aluminized mandrel bent tubing with deep slip-fit connections. Aligns for left,...
$118.05
from $94.44
# 469136
Flowmaster® - Scavenger Series Aluminized Steel Turn Down Pipes
(0 reviews)
Universal Aluminized Steel Turn Down Pipes by Flowmaster®, 1 Pair. The venture reducer cones from Flowmaster make for easy transition from one pipe diameter to another. They are 8.00" in length, made in 16 gauge aluminized tubing...
$58.1
from $46.49
# 469152
Flowmaster® - Scavenger Series Y-Collector
J
jbburn
Thank you for the information. I called summit and they told me they don't carry any headers that will fit a standard trans. They told me to call flowtech's tech line. So I did an got the same response. broncograveyard also doesn't have any to fit a manual trans. Any help would be appreciated thanks. Or am I going to just have to buy the stock manifolds?
ok;
Call Hedman
They do not list Std or auto trans, just;
Ford Bronco 1981
CID: 302
Liter: 5.0
http://www.hedman.com/site/?d=22&dt=108&YearID=1981&MakeID=54&ModelID=633&CID=302&limit=20
ELITE Ultra-Duty Street Headers
thicker flanges. stronger wall tubing and a thermal coating that withstand full-throttle thrashing and torturous towing.Part # 89358
Collector Size
3"
Finish Type
HTC Ceramic-metallic coated mild steel
Head ****** Gasket
27340
Tube Design
FULL LENGTH
Variations
89356, 89358
1-1/2" FULL LENGTH
They also show;
Standard Duty HTC Coated Headers
Standard Duty Uncoated Headers
Call L&L
http://www.landlproducts.com/details.aspx?cID=4&BP=0&scID=0&ItemID=1098
302/351W Chassis Exit 2WD/4WD
1980-96 Bronco
1980-95 F150/F250/F350
1/2" Thick ******
1 1/2" Primary Tubes
4 into 1 Header
ELECTROLESS NICKELSHIELD PLATING NOT AVAILABLE AT THIS TIME USE PART # 79730AP 1980-90 Bronco 1980-90 F150/F250/F350 Complete With Hi Performance Header Gaskets, Collector Reducers and Installation Hardware. 1/2" Thick ****** 1 1/2" Primary Tubes 4 into 1 Header
I tried Bassani, but none avail for 81 301 std trans
http://www.bassani.com/
Same for;
http://www.bbkperformance.com/
http://fordperformanceracingparts.com/trucks/truck.asp
http://racing.ford.com/parts.html
http://gibsonperformance.com/truck.php
http://pacesetterexhaust.com/shorty-headers.aspx#ford
GL!
Fryman22
