yo Ant,
Hopefully someone else can give you pertinent info.
All I have ever found was this;
Installation, 7.3L W/D60 COILS & 6.0L wD60 Coils in Two 93's (owned by David C)
Source: by David K at
http://www.dieselpowermag.com/features/ford/0810dp_1993_ford_bronco_powerstroke_diesel/index.html
Excerpts;
"Fitting the '06 Dana 60 front axle proved to be a little more involved than swapping the leaf-sprung axle in, but David said the ride improvement made the effort worthwhile. Like the '02 Dana 60 in his 7.3L Bronco, the '06 Super Duty Dana 60 was also fitted with 3.73 gears, but unlike the '02 axle, it was mounted with coil springs and radius arms. Unfortunately, the radius arms on the Bronco were not compatible with the Super Duty axle, so David used a combination of Fabtech radius arms, coil springs, and sway-bar end links to install it. New mounts for the track bar, sway bar, and coil-spring buckets were built. An '06 Super Duty steering box was also retrofitted to the Bronco's frame."
"Beginning with the '02 model year, all Super Duty trucks came from the factory with a Dana 60 front axle, so that's what David swapped into the front of his 7.3L Bronco. Fitted with 3.73 gears, the 1-ton axle was far better suited to handle the weight and torque than the original 3.55-geared Dana 44 Twin-Traction Beam (TTB) axle.
The front Dana 60 axle was bolted to the Bronco with stock Super Duty leaf springs and hangers. The rear shackles were adapted to the frame with fabricated steel mounts. From this angle, you can also see how the Bronco's E4OD transmission was replaced by a Super Duty 4R100 transmission."
GL Ant!
