TIMING CHAIN
rogmit
I HAVE A 1992 FORD BRONCO WITH A 5.8. I GOT A QUESTION ABOUT TIMING CHAIN PLAY, I NEEDED TO REPLACE THE WATERPUMP BECAUSE IT WAS LEAKING AND THE TIMING CHAIN GASKET LOOKED LIKE IT HAD BEEN SEEPING OIL SO, I PULLED THE COVER OFF AND NOTICED THAT ONE SIDE OF THE CHAIN IS TIGHT BUT THE OTHER SIDE OF THE CHAIN I COULD PUSH IN AT LEAST AN INCH OR MORE. DOES THAT MEAN THE TIMING CHAIN NEEDS REPLACING AND IF SO, I GUESS YOU CHANGE THE GEARS TOO. ANY HELP IS WOULD BE APPRECIATED.
yo Rog;
96 Bronco-F-Series Workshop Manual (PARTIAL)
http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Same as 92 and most earlier years exc. for OBD II, 4WABS (93-96); ABS (87-92); Air Bag (94-96); 3 ***** Automatic Locking Hubs (Built from May 95 through 96) and a few other items
(still need time to go through all pages to confirm other differences)
see Section 03-00: Engine, Service
SERVICE PROCEDURES
Timing Chain Deflection (5.0L, 5.8L, and 7.5L)
1.Remove engine front cover (6019) as outlined in Section 03-01B (5.0L and 5.8L MFI) or Section 03-01C (7.5L MFI).
2.Rotate the crankshaft (6303) so the camshaft sprocket and crankshaft sprocket timing marks line up.
3.Mark the top link(s) of the timing chain.
4.Have an assistant hold crankshaft with a suitable tool so it cannot turn.
5.Place a machinists scale above the timing chain so you can measure its movement.
6.Put a torque wrench and socket on the camshaft sprocket bolt.
7.Apply a maximum of 20 Nm (15 lb-ft) torque in a clockwise direction.
8.Note location of marked link on scale.
9.Apply a maximum of 20 Nm (15 lb-ft) torque in a counterclockwise direction while measuring the amount the marked link moves.
10.Movement should be less than 3.175mm (0.12 inch). If movement is excessive, replace timing chain as outlined in the appropriate Section 03-01B (5.0L and 5.8L MFI) or Section 03-01C (7.5L MFI).
http://www.diesel-dave.com/vehic/manual/stj/stj30019.htm
