hello all.
I am starting out with a 87 ford bronco efi 302 "Non-Roller" /aod auto trans. the engine was very tired and so I pulled it to have it rebuild and found that it had a cracked block.
I then found a 302 efi "Roller" from a 93 ford bronco which I have rebuilt and am about to install. I did get the engine wiring harness from the 93 bronco however the plugs will not fit so I will have to splice the to harness's together. My question is should I get a new dizzy for a 87 bronco or should I wire up the dissy that came with the 93 bronco? Since I am going from no roller to roller engine do I need to rewire the fuel injectors differently or is there any thing else I need to do to get it to run in my 87?
Thanks
Thanks
