Replacing Shocks
pj31704
Texas
I am looking to replace the Shocks/Coils/Leaf Springs. I have no experience with any suspension replacement and I am curious if anyone has any recommendations on parts, tips on replacement, etc.
I also am wondering how I know which size I will need. Any help will be greatly appreciated!
Hi PJ..,
You always seem to catch me huh..?
Both www.tomsbroncoparts.com   & www.Wildhorses4x4.com  have great state-of-the-art lifts for the EB.
---Both are in Calif.---
It's a 3-4 banana job and SAFTY is job 1..! (Can't have too many supports/jack-stands under the frame)
I strongly recommend the 11pak rear leafs for ride comfort.
All EB stores have dual shock set-ups but it's NOT necessary..., especially with todays good shocks.
Lift size all depends on your usage.  I did the 2.5 inch as I do rough to really rough trails & hill climbs.
Big lifts are more for rock-crushing & usually req. several other changes to get the alignment &
driveshaft angles back in a safe setting.
And, of course the price goes up, the bigger the lift. (more parts/mods, etc.)
I had never done this B/4 & now I've done 3.
The front is a bit tricky & one tough part is getting the radius arms parallel or it could cause the
truck to sit lop-sided.  In fact.., measure ALL FOR CORNERS B/4 you start as there could be a
low point already. If so.., it's not always likely it will go away with the new springs, etc.
Let me know what you decide & I'll give you some more pointers.
P.S. Several other EB stores have the lifts however, I have no experience with them.
It's all fun..!
