blown head gasket
rogmit
Ok the smoking of oil out of the tail pipe smells like oil and their is no water dripping out of tailpipe but I checked the oil today and their are signs of water which would indicate a blown head gasket but the plugs are black and smell like gas and the water pump is leaking.Is there a possibility water is getting into the oil because of the water pump or could I be dealing with more than one problem?
Hard to tell from here, but I'd say you are dealing with more than one problem.  Attack one at a time, or it may be easier to pull the engine to do it.  Either way, fix the water pump and most likely you need to pull the head.
Grizz
Sacramento California
Compression check the cylinders.  if one bank is extremly low than the other then its a blown gasket.  if not then go back to the water pump and gasket behind the timing chain cover.
