ignition will turn but won't start
sally
I put my key in the ignition and it will turn but it turns to far and it won't start. Its a '86 and its my way to work really need to fix it soon. Any advice?
YO sally,
welcome!
First, sorry about Caps! am having vision issues now and hunt & peck is the Norm for me.
REAL FAST AND SIMPLE CHECKS FIRST;
DOES HORN HONK AS USUAL, LOUD OR JUST A WHIMPER BEEP);
if NOT, CHECK BATTERY VOLTAGE; OR GET A JUMP
SAME FOR HEADLIGHTS; ARE THEY bRIGHT AS USUAL? OR DIM?
Is IGN KEY CYLINDER LOOSE IN cOLUMN?
Detailed Testing
How to Troubleshoot a No Start
(Ford 4.9L, 5.0L, 5.8L)
http://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-troubleshoot-a-no-start-1
Can borrow a spark tester at some parts stores or diy; google it
From the sound of it, you probably have a linkage problem between the key cylinder and the actual switch.  The actual switch is mounted on top of the steering column under the dash.  It is easy to check.  Put the key in the cylinder, position your self so you can see and feel the linkage rod on top of the column.  Turn the key to see if the rod moves.  If it does, you probably should do the switch adjustment, ( http://broncozone.com/topic/7243-ignition-switch-adjustment-proceedure/ ).  If it doesn't move then the problem is probably the linkage dog between the key cylinder and the switch push rod. That will take a little more work.  Let us know.
Good Luck,
S
sally
Thanks guys it eneded up being the ignition lock.
