Catalytic Converter on After Market Exhaust
BroncoStar
Ok, so I had true dual exhaust put on my 93 Bronco (351) a few years ago. Now I live in Arizona and have to pass an emissions test...ugh! While my truck passed the emission test, it failed the visual inspection because it didn't have the cats on it....so I put the OEM exhaust back on it and it passed just fine. Now I want to put the dual exhaust back on, but add cats for the next time I have to get an emissions test. Will two separate cats work? and will they fit? The straight pipes ran side by side down the undercarriage until they get to the mufflers (magna-flows) and then split off to exhaust off the side of the truck. Any advice would be awesome! Thanks!
Check w/your MVC on this esp. the visual inspection process; they may Not let you pass with the duals even though you add cats.
I looked through this site for more info;
http://azdot.gov/mvd/faq/vehicle-services
What equipment (lights, mirrors, etc) is required on my vehicle to drive it on the streets and highways?
Arizona law in Title 28, Article 16 provides this information. If you have specific questions, contact the Arizona Department of Public Safety.
miesk5 Note; see http://www.azleg.gov/ArizonaRevisedStatutes.asp?Title=28
Article 16 Equipment
28-921 Applicability of equipment requirements
28-922 Lighted lamps required
28-923 Visibility distance; mounted height of lamps
28-924 Motor vehicle head lamps
28-925 Tail lamps
28-926 New motor vehicles; reflectors
28-927 Stop lamps
28-928 Applicability of lighting laws
28-929 Additional lighting equipment required on certain vehicles
28-930 School bus lighting equipment; standards and specifications
28-931 Lamp colors
28-932 Reflector and lamp mountings
28-933 Reflector and lamp visibility
28-934 Obstructed lights not required
28-935 Lamp or flag on projecting load
28-936 Lamps on parked vehicles
28-937 Lamps on other vehicles and equipment
28-938 Spot and auxiliary lamps
28-939 Signal lamps and devices
28-940 Additional lighting equipment
28-941 Multiple beam road lighting equipment arrangement
28-942 Multiple beam road lighting equipment usage
28-943 Single beam road lighting equipment
28-944 Lighting equipment on motor driven cycles
28-945 Alternate road lighting equipment
28-946 Number of driving lamps required or permitted
28-947 Special restrictions on lamps
28-948 Snow removal equipment lamps
28-949 Selling or using lamps
28-952 Required brake equipment
28-953 Brakes on all‑terrain vehicles and motor driven cycles
28-954 Horns and warning devices
28-955 Mufflers; noise and air pollution prevention; emissions control devices; civil penalty; exception **** see http://www.azleg.gov/FormatDocument.asp?inDoc=/ars/28/00955.htm&Title=28&DocType=ARS
28-955. Mufflers; noise and air pollution prevention; emissions control devices; civil penalty; exception
A. A motor vehicle shall be equipped at all times with a muffler that is in good working order and that is in constant operation to prevent excessive or unusual noise.
B. A person shall not use a muffler cutout, bypass or similar device on a motor vehicle on a highway.
C. The engine and power mechanism of a motor vehicle shall be equipped and adjusted to prevent the escape of excessive fumes or smoke.
D. Beginning with motor vehicles and motor vehicle engines of the 1968 model year, motor vehicles and motor vehicle engines shall be equipped with emissions control devices that meet the standards established by the director of environmental quality.
E. A person who violates this section is subject to a civil penalty of at least one hundred dollars.
F. This section does not apply to an electrically powered motor vehicle.***
28-955.01 Motorcycles; noise level equipment; unauthorized equipment
28-955.02 Motorcycle noise level rules
28-955.03 Exemption for racing motorcycles; definition
28-955.04 Exhaust system; visual inspection; requirements; civil penalty
28-956 Mirrors
28-957 Windshield wipers required; golf cart exception
28-957.01 Windshields required
28-958 Tire equipment restrictions
28-958.01 Rear fender splash guards
28-959 Safety glass required; applicability; denial or suspension of registration; definition
28-959.01 Materials on windows or windshield; exceptions; requirements; violation; definitions
28-960 Flares; warning devices; requirements
28-961 Display of warning devices; disabled vehicle
28-962 Vehicles transporting explosives; rules
28-963 Image display device; prohibition; exceptions; definition
28-964 Motorcycles; all‑terrain vehicles; motor driven cycles; equipment; exception; prohibition
28-965 Fuel tank caps
28-966 Neighborhood electric vehicles; speed; restrictions
Article 17 Inspection of Vehicles
28-981 Vehicle equipment; safety requirement
28-982 Vehicle and equipment inspection; notice of repair or adjustment
Here is some info & pics that I have collected over the years;
93 w/Bassani Y-pipe & high flow cat pics in a 5.8
Source: by Dustin J (SOLD, rokhrse, sukngas) at http://www.supermotors.org/clubs/superford/vehicles/registry/detail.php?id=1309&s=33328
Dustin shows the Blue Hi Temp Silicone Air Inlet Tubing pic.
Dustin wrote in a defunct site, "...Bassani overheating transmission??
I think I finally figured out why I blew a front seal out of my trans the last wheeling trip. The trail was nothing the my broncos used to seeing. It also happened fairly quickly after starting the trail. I was baffled up until the other day when I was under the rig. i could not figure out why it decided to pop the seal on a relatively new trans, never ever had an overheat problem even in 115 summer weather in the desert. the kicker is this was the first hard run I had been on since putting the bassani y-pipe and cat on. Basically once hot and under a load like trying to climb a rock the front seal would **** trans fluid everywhere, but normal driving its fine just a drop here and there. Just has issues when heat and pressure build up.
The damn cooler lines run way too close to the-pipe for my liking. I think this is causing my issue.
They are not touching like the picture suggests.
I know aftermarket stuff has issues but damn someone like bassani you would think would have done their homework. It just irritates me that I have issue offroad, I hate having to wrench on my rig when wheeling over something stupid. Not to mention this causes me lots of hours in labor just to pull the trans down and replace the seal, not to mention the time trying to figure out how to repair the issue. I have an external trans cooler(factory). And I was not hammering on the engine. It was slow crawling so very little air flow, under heavy load(wedged between rocks). It was an overcast day and not all that hot. I have no doubt it got hot and puked and I am pretty sure these lines caused it. Like I said no problem before now there is a problem after exhuast..."
Dual info & pics in a 95 5.8 (same for your 93)
Source: by bds3795 at http://www.supermotors.net/registry/21353/74667
Duals & Flowmaster™ Muffler & Split pics in a 94 5.8 pics
Source: by Eric B (BlazenXLT) at http://www.superford.org/registry/vehicles/detail.php?id=4956&s=19744
Duals & Bassani Y pipe & Walker DynoMax® Turbos & 2.5 inch pics in a 94 5.0
Source: by Ken B (Kenny's 94) at http://www.supermotors.org/clubs/superford/vehicles/registry/detail.php?id=9319&s=27488
Swap, 2 to 1 Advice "t is illegal to replace or modify emmisions control equipment with other-than-stock equipment. But the pre-cats are only there to reduce emmissions until the main cat gets warmed up. So yes, you can go to one cat and you might even burn cleaner with a aftermarket high-flow cat. But you will run the risk of not passing visual inspection."
Source: by Froggmann (Ken P) at http://web.archive.org/web/20090106123718/http://www.froggmann.com/Faq/catone.htm
BroncoStar
Thanks for all the info! I will definitely talk with the mechanic about what he can do here in Arizona and stay within the regulations.................Thank you!!!
Lana Kane
