Bronco Side Exterior Molding
BroncoGal1236
I recently hit a deer in my white 1996 XLT bronco. It took off the side molding. Just one piece, the rear quarter, is missing. Also my door piece has been bent.
I am wonder if anyone HAS or knows where to find this molding. Its been discontinued by Ford. It runs along the bottom of the XLT broncos and it is the same color as the car with chrome in the middle. I really want to find a piece so my car can be fixed back to the way it was before the accident.
So, I am looking for the white and chrome exterior side molding. In the Picture you can see it on the bottom running along the whole car.
As Bob advised;
also check w/local body shops, they have in-house or subcontractors that install mouldings.
Also, fyi; 96 Bronco-F-Series Workshop Manual (PARTIAL) by Ford via http://www.diesel-dave.com/vehic/manual/stj/stjleft.htm
Section 01-08: Trim, Exterior
REMOVAL AND INSTALLATION
http://www.diesel-dave.com/vehic/manual/stj/stj18007.htm#extract_165
Mouldings, Exterior
Body Side Protection
To install or repair the body side moulding (extruded PVC with two-way tape), perform the following procedure.
Removal
1.Completely clean sheet metal surface area around moulding with isopropyl alcohol and a clean, soft cloth.
2.Before removing moulding, mark moulding location on top and at each end of moulding with masking tape
3. CAUTION: Use care while removing moulding to prevent damage to the paint or sheet metal surface.
NOTE: Do not heat moulding or sheet metal surface; this only increases the adhesion. Cold temperatures of 0°C (32°F) and below allow for easier removal of moulding.
Using a nylon wedge, start at rear of door, wedging nylon tool between moulding and door. At the same time, pull moulding away with steady tension. Remove and replace one moulding at a time.
4.Once a few inches of moulding are free, grip moulding with both hands and pull the moulding slowly toward the front of vehicle.
5.NOTE: Not all of the tape will come off with the moulding. White or gray acrylic tape is most easily removed by gently stretching.
Grip tape at one end, lift and pull away slowly about 12.7mm (1/2 inch) at a time, then grip and pull again. Small pieces can be removed by rolling thumb across sheet metal surface.
6.To finish removing the tape, the recommended method is with 3M Scotch-Brite® Moulding Adhesive and Stripe Removal Disc, 3M Part No. 07501 or 07502.
7.When all tape is removed, wipe area with isopropyl alcohol and clean soft cloth, ensuring that all tape residue and road dirt is removed. A clean surface is required for application of new moulding. Should paint surface be damaged during moulding removal, surface should be repaired using paint repair procedure. Refer to Section 01-00.
Installation
1.NOTE: Mouldings should not be installed on vehicle unless sheet metal surface temperature exceeds 27°C (80°F) and moulding is at a minimum of 22°C (71°F).
Apply new moulding.
2.Starting at front of door moulding, pull back tape protective liner approximately 75-100mm (3-3.9 inches). Do not touch or contaminate tape surface.
3.Line up moulding with marks on masking tape at rear of door and press gently forward on door removing protective liner as you proceed forward. Be sure part is lined up correctly; once tape sticks, part cannot be removed.
4.Remove masking tape and wipe area under masking tape with isopropyl alcohol to remove residue.
5.Press moulding on with hand roller applying a minimum of 140 kPa (20 psi) pressure to ensure positive tape adhesion
Our sponsor Jeff's has the standard BS moulding in Black plastic side molding with chrome strip in center. Self adhesive tape on back of moldings. 3" wide
molding
http://shop.broncograveyard.com/92-96-Bronco-Pre-Cut-Moulding-Set/productinfo/35165A/
I may have to buy a door section for our 96.
Also Parts Catalog 92-96 Bronco (Partial) by Ford http://www.supermotors.net/registry/3549/77108
INDEX, paint codes, front bumper, PAGE 833
ABS module, sensor, decel switch, etc., air bag module, monitor, sensor, etc., underhood dimensions in mm, cruise control, wheels, frame, PAGE 836
front suspension, PAGE 837
grille, front lamps, headlight, hood, engine cooling: radiator, fan, water pump, shroud, page 834
paint stripes incl. NITE, HVAC, fender, PAGE 835
steering column & linkage, gear, pump, wheel & horn switch, Page 838
steering cont'd, ignition switch, Engine, Page 839
engine & trans CONT'D, alternator, battery cables, air intake, hood, HVAC CONT'D, Page 840
center console, dash, instrument panel, cowl, PAGE 841
front floor pan, seat belt, interior & exterior door trim, cab step, page 842 See Ford long version part numbers; Google the ones that seem correct as for description;
Search at;
for obsolete parts by Ford pn:
http://www.partsvoice.com/
http://www.rearcounter.com
http://www.greensalescompany.com
NOTE: Do not use any separators("-" or" *") in the part number. Be sure to use a numeric "0" and not an alpha "O" as the year indicator (2nd position).
(example: "D0OZ" not "DOOZ")
door CONT'D, cab roof, camper top, overhead console, page 843
tailgate, quarter glass, interior & exterior trim, PAGE 844
fuel tank, rear suspension, 8.8, floor pan, glass, tire carrier, rear lamps, high mtd. stop lamp, page 845
license lamp, bumpers, grille, CONT'D, PAGE, 846
engine & transmission CONT'D, exhaust & catalytic converter, air intake, hood, HVAC, CONT'D, Page 848
fender, paint stripes, ext trim, wheels, CONT'D, page 849
wheels, front suspension, steering linkage/column, CONT'D, PAGE 850
frame, strg column, windshield, cowl & dash, CONT'D PAGE 851
instr panel, ctr console, front floor pan, interior door trim, seats belts, CONT'D, PAGE 852
glass, vent, cab roof, camper top, side quarter glass, quarter panel, CONT'D, PAGE 853
quarter panel, tailgate, rear suspension, 8.8, fuel tank, tire carrier, CONT'D Page 854
fuel tank, rear floor pan, lamps, rear bumper, CONT'D, PAGE 855
http://www.hollanderparts.com/
Select All Parts
year, etc, then FORD TRUCK
or
http://www.copartfinder.com
Has Vehicle Pics!
http://www.car-parts.com/
http://www.picknpull.com
This is a Company name w/yard locations in various states
96 Bronco Brochure by Ford via miesk5
http://www.supermotors.net/registry/media/877777
96 Bronco Owners Guide by Hiller Ford
http://www.hillerford.com/resource_library/owner_manuals_pdf/1996_owner_manuals_ford/96bronco.pdf
yo, We have had heavy rain and high winds, so I had to enter the info above in separate entries to avoid power outage.
I also edited my last reply to include;
http://www.supermoto...ry/media/877777
http://www.hillerfor...rd/96bronco.pdf
Click Refresh to see those two URLs
And from your pic, I don not see indication that your 96 had the optional Sport Package, so in conversations with potential sources let them know that; and do I see red in the moulding?
Some new moulding can be obtained that May be same; but are paint to match (PTM suffix)
and I see this is correct New URL for http://www.copartfinder.com/finder/searchMake.do
BroncoGal1236
BroncoGal1236
It is not XLT sport just XLT. The picture is during sunset so the colors of the sunset are reflecting off the chrome. I have found a lot of after market stuff but nothing like whats on the Bronco. When your talking about some can be obtained but has to be painted to match, do you mean off another bronco or is there something to buy?
BroncoGal1236
BroncoGal1236
I've also been all over ebay. Can't find anything. I have been in connact with local junkyards but they haven't had anything yet
yo, As for the paint to match, I have not found any new pieces anywhere;
Here is our 96; bought new w/Ford black/chrome moulding.
BroncoBret
