yo 78,
WELCOME!
Since AC did not work either, will skip usual suspects such as a stuck open thermostat
with the engine warm and heater running, feel your heater hoses. They should be the same(or close) temp. If one is way hot and the other luke warm then I would suspect a clog in the heater core
there is a water valve in-line on the heater hose. Mine corroded shut on our ex 78, and I had no heat. The water valve is on the heater hose & is vacuum operated. The valve could be stuck shut or the vacuum hose could be unhooked. If the hose is hooked up, pull it off while the motor's running & see if there's vacuum. Trace it back/ replace hose
Nate wrote: "there is a cable that comes from the dash to a little silver arm sticking up on the heater /Ac evap housing under the hood. My cable is froze up so I just removed it and pushed it little arm all the way to one side. I have full heat all the time, but it works."
blend door cable is connected?
Blend Door Control Cable (aka Air Blend Door Cable) Location, Behind Control Panel Diagram in a 78 by Indybronco (Lula Mae) at
http://www.supermotors.net/clubs/superford/registry/media/307033
or it gets Hot, but no blower operation?
Here is a wiring diagram
79 Ford Bronco Wiring Manual by topsig
http://www.supermotors.net/registry/24302/83503
For HVAC System See pages 39 (major component location depiction)
40-43
40 is heater only models blower troubleshooting
41 is heater and AC models blower troubleshooting
42 is Operation, troubleshooting & diagrams; describes water valve and shows blend door
43 is Vacuum Diagram for vacuum motors, etc.
73-79 F Series and 78-79 Bronco Heater Core and Heater Motor Replacement For Trucks with Factory A/C or Hi/Lo Heaters
http://www.ncspecialties.com/autobody/heater/index.htm
